Turbo feed line question
I just have a quick question about feeding oil to the turbo. I currently have lsvtec and the oil is being fed to the head from a t-fitting where the oil pressure sensor goes in the block. Can I just put another t-fitting right before the head and run the line to the turbo? Or is this going to starve either the head or the turbo. If I do it in this configuraton, what size steel braided lines are going to be big enough to feed both?. I'd rather feed both through a sandwich plate, but I am running out of money as I near the end of my project. Also, any suggestions on where to purchase all the braided lines? Sorry if this is has been covered, but I don't have the luxery of time on my side right now either. Thanks.
you can buy an adapter it screws on to the oil filter adapter, and the filter screws on to that.... it has a feed line on it.... save you time... turbonetics i thing makes it... its like $40
Stealthmode firewall kit. I've used it, and it's definately a nice piece. Makes it really easy to run all your sensors and feed lines.
Edit: To answer your other questions, you should use -3 an line for it all, which is what the kit contains. You shouldn't starve anything with this setup.
