will a broken knock sensor disable VTEC?
Old Apr 24, 2006 | 09:07 AM
firstswap's Avatar
Default will a broken knock sensor disable VTEC?
I broke my knock sensor while swapping a D16y8 for a JDM D15B. the swap went really well except i broke the knock sensor. i had to put the D16 intake man on because i had an obd2 wiring harness and the D15 was obd1. it runs pretty good, but no VTEC. i am throwing 2 codes, knock sensor, and crank sensor. My question is will either of those cause the VTEC not to work?
Old Apr 24, 2006 | 09:24 AM
komat's Avatar
Default Re: will a broken knock sensor disable VTEC? (firstswap)
yes
Old Apr 24, 2006 | 09:53 AM
firstswap's Avatar
Default Re: will a broken knock sensor disable VTEC? (komat)
thank you for the fast answer. i read about a way to bypass the knock sensor using a piezo transducer from radio shack. after i take care of that code i will try to figure out something with the crank sensor. thanks again.
Old Apr 24, 2006 | 04:40 PM
spooncivic1's Avatar
knock sensor has nothing to do with vtec....
search for it and read
Old Apr 24, 2006 | 06:06 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
Incorrect.
B18CXr's Avatar
Nope
Old Apr 24, 2006 | 06:08 PM
loudassVTEC's Avatar
Default Re: will a broken knock sensor disable VTEC? (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">will a broken knock sensor disable VTEC?
Nope</TD></TR></TABLE>
Ran with no knock on my b16 for six months. VTEC engaged no problems.
SingleCamin
May 19, 2009 08:23 AM
carraway99
Feb 17, 2005 10:29 PM
codeh22a4
Apr 8, 2004 12:51 AM
Audi A4
Sep 18, 2003 12:03 AM
