is it bad to hot tank a sleeved block???
ive been hearing mixed reports about hot tanking a sleeved block. i know mine(aebs sleeved ls block) was hot tanked after being bored, and im kinda curious toward this. what would be some negative effects??? id hate to have my 1000+dollar investment compromised due to a 60 dollar hot tank
Re: is it bad to hot tank a sleeved block??? (blackeg)
bump for info.....Im in the same boat
what are other options to get the shavings out after bore/hone???
Re: (Moto-C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moto-C »</TD></TR><TR><TD CLASS="quote">ask the sleeve installer what they say. Golden Eagle say with the instruction/warranty included not to hot tank their sleeves</TD></TR></TABLE>
Oops.....well I had my GE hot tanked not too long ago after a refresher......guess I will find out if there are any negatives
Re: (LilCivic04)
Sometimes hot tanking will un seat the sleeves and allow them to raise up a few thou. If you were to surface the block in that condition, the sleeves would then re seat themselves in a dropped position.
Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">Sometimes hot tanking will un seat the sleeves and allow them to raise up a few thou. If you were to surface the block in that condition, the sleeves would then re seat themselves in a dropped position.</TD></TR></TABLE>
makes good sense. when assembling my bottom end the sleeve surface was a lil above the block deck surface. i had my head off about 3k miles after building the motor and everything was flush again. i have some slight coolant mixing issues which is why i asked this question
I actually dipped my head into a bucket of drain cleaner (industrial strength) and It removed everything. Just let it sit over night, I did the same with my block. I am going to take pictures tomorrow and show everyone how it came out, so far the block looks really great!
Re: (earl)
This is what I was thinking.. Since the expansion rate of alumnium and ductile iron are different..
Re: (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">
This is what I was thinking.. Since the expansion rate of alumnium and ductile iron are different..</TD></TR></TABLE>
yea my sleeves were definately up a few thousandths when i got the block back, but as i said after having the head on there for a few thousand miles, the sleeve and block deck surface are both level wiht no evidence of sleeve sinking or anything.
here is my concern, im loosing coolant, it can see a lil of it in my oil when i change it, but it definately can be seen on my breather filter (catchcan doesnt have much coolant in it).
now this head was on my last motor when i blew my #3 sleeve to pieces. im thinking that i punctured a coolant passage in the head somewhere and its either dropping into my cyls a lil bit, or it is mixing with an oil passage in my head. the problem was worse but i changed headgaskets and it seems to have slowed down a lot, but not totally stopped. my machinist said that he didnt see any damage to the head when he was machining it after the motor blew.
asubennett
10
03-20-2005 09:20 PM
GreddySi99
10-15-2003 09:35 AM
