HOW MANY PEOPLE
Old Apr 25, 2006 | 09:59 PM
JLHDOHC's Avatar
Default HOW MANY PEOPLE
I need to know how many people are running without the oil squirters and if they are have they noticed any problems in their pistons..I recently got my block back from the machine shop and was putting it together and noticed oh **** forgot the squirters after already have the piston and rods in. I was able to get them in 2,3,4 all tighten down but number 1 loose as a goose but can thread the oil squirter bolt completely down till it sits flush with the block and tq's to 13lbs like suppose to should i plug the other 3 with the golden eagle plugs and just leave the factory bolt tq or any IDEAS please help cause they dont make a helicoil that small
Old Apr 25, 2006 | 10:03 PM
liam821's Avatar
25 Year Member
Default Re: HOW MANY PEOPLE (JLHDOHC)
d-series dont have oil squirters...so lots of people are running without them.
However, my next dohc ZC block i build im going to have them custom installed.
liam
Old Apr 25, 2006 | 10:04 PM
tdo's Avatar
tdo
some people block it off so their oil pressure stays higher.
some say its better to block it off.
Old Apr 25, 2006 | 11:18 PM
JLHDOHC's Avatar
Default Re: HOW MANY PEOPLE (liam821)
why are you having them installed is it because its better to have them
Old Apr 26, 2006 | 06:56 AM
DJ Gurgla GSR's Avatar
what do you mean its 'loose as a goose' on cylinder one?
I believe that one may be installed incorrectly. like not sitting flush on the block (theres a pin & hole that need to line up to sit properly)
Simple mistake and easily made when trying to bolt them in once the crank / rods are in the way
Old Apr 26, 2006 | 11:13 AM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JLHDOHC &raquo;</TD></TR><TR><TD CLASS="quote">why are you having them installed is it because its better to have them</TD></TR></TABLE>
It squirts oil on the pistons, helping to keep them cool. Which should in turn help with durablity of the pistons and rings, and i would imagine help with detination (correct me if im wrong).
liam
Old Apr 26, 2006 | 03:33 PM
JLHDOHC's Avatar
Default Re: HOW MANY PEOPLE (DJ Gurgla GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ Gurgla GSR &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean its 'loose as a goose' on cylinder one?
I believe that one may be installed incorrectly. like not sitting flush on the block (there's a pin & hole that need to line up to sit properly)
Simple mistake and easily made when trying to bolt them in once the crank / rods are in the way</TD></TR></TABLE>
threads are gone......and wont tighten down
em1 Ziggy
May 12, 2006 11:08 PM
mo0cow
Oct 26, 2005 04:36 AM
Boostless97Lude
Jan 18, 2003 08:19 PM
highbrid
Oct 14, 2002 08:33 AM
One8Hatch
Oct 18, 2001 12:24 PM
