compression ratio
Old Feb 6, 2008 | 04:58 PM
94civicgsr's Avatar
Default compression ratio
what compression ratio is better for a turbo set up( like 9:1 or 9.8:1 or 12.5:1) the turbo is a t3/t04e, tail bov, tail 38 mm watsegate and im wanting like 400whp in my gsr. je forged 81mm pistons, eagle crank, eagle rods, skunk2 mani, skunk2 turbo cams, acl bearing and arp studs with either a metal hg or a cometic
Old Feb 6, 2008 | 05:18 PM
Schister66's Avatar
Man U FTW
well it depends on the fuel grade you plan to run. I dont think you're going to find something high enough (while being affordable) to run the 12.5:1, but the 9.8:1 would be a decent option. I'm planning to run a 9.8:1 CP in my new build....details in sig
Old Feb 6, 2008 | 06:03 PM
94civicgsr's Avatar
Default Re: (Schister66)
well isnt a stock gsr comp ratio 10.0:1
Old Feb 7, 2008 | 12:37 AM
AutoXEF9's Avatar
* B A N N E D *
Default Re: (94civicgsr)
9:8.1 is pretty decent
Old Feb 7, 2008 | 05:13 AM
hawkturbo's Avatar
i have a ???? 180 compresion ratio is 9:8.1 or 9:5.1
Old Feb 7, 2008 | 03:49 PM
hawkturbo's Avatar
Default Re: (hawkturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawkturbo &raquo;</TD></TR><TR><TD CLASS="quote">i have a ???? 180 compresion ratio is 9:8.1 or 9:5.1</TD></TR></TABLE>
Up!!!!!!!!!
Old Feb 8, 2008 | 03:52 AM
hawkturbo's Avatar
Old Feb 8, 2008 | 04:29 AM
turbotypeR@SPEC's Avatar
25 Year Member
it could be either one. there are more things than just the compression ratio that contribute to the psi from a compression test. you could get 180 from either 9.8:1 or 9.5:1. if ths is a street car that will be on pump gas, i would build it with 9.0:1.
Old Feb 10, 2008 | 09:21 AM
AutoXEF9's Avatar
* B A N N E D *
Default Re: (AutoXEF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXEF9 &raquo;</TD></TR><TR><TD CLASS="quote">9:8.1 is pretty decent</TD></TR></TABLE>
GSRkevTec
Jul 4, 2016 08:12 PM
KooK
Feb 14, 2006 12:13 PM
Ls InTeGrA RaCeR
Sep 12, 2005 06:16 AM
Maxboost00
Oct 1, 2004 10:42 PM
JDMSiGuy17
May 13, 2004 03:51 PM
