just wanted some epinions on this turbo
did some search on this turbo but couldnt find anything so i decided to post it up. so i was wondering if anybody used the garrett t3/t4e 57 trim turbo? http://www.atpturbo.com/Mercha...e=TBN was wondering if this turbo was capable of making 400whp on my b18c1 on pump gas. wanted to see couple peoples set up with this turbo.
Re: just wanted some epinions on this turbo (b18c1turboem1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1turboem1 »</TD></TR><TR><TD CLASS="quote">did some search on this turbo but couldnt find anything so i decided to post it up. so i was wondering if anybody used the garrett t3/t4e 57 trim turbo? http://www.atpturbo.com/Mercha...e=TBN was wondering if this turbo was capable of making 400whp on my b18c1 on pump gas. wanted to see couple peoples set up with this turbo.</TD></TR></TABLE>
LOL. this turbo is probably the most commonly used turbo on b-series engines. maybe even hondas in general. there is plenty of info on this site regarding that turbo
Re: (b18c1turboem1)
Re: (agrn93ls)
It will be a little difficult to answer your question since you didnt specify your setup and which a/r exh housing you will want to use, spool characteristics etc, but the higher power you want to make and higher in the rpm range the higher a/r will be what you need.
but yes the turbo will meet your goals in a generalized answer to go with your general question.
