Edelbrock IM questions...please help out if you can
Hey all, I completely didn't think about what Throttle cable and bracket I would need to run now with a RPM services 72mm TB and Edelbrock IM, but I assume I can run a stock ITR throttle cable, and if need be, just make my own bracket to bolt up to the manifold from what I've been reading.
My real question is, can someone post pics of where they mounted all their stock equipment on the Edelbrock for me to check out? Things like the air intake temp sensor, IACV, map sensor, etc. I think I heard or read somewhere that the Edelbrock manifolds work just like stock, in that they allow all stock sensors to bolt up in the same spots?
If anyone has any top and bottom pics with everything assembled on it, that would be great! Thanks
i HAS questions ?
Re: Edelbrock IM questions...please help out if you can (totsie7944)
Not my picture, found it in a for sale thread.
Thats for B16/B18C5 heads. You can see the IAT sensor and IACV mounted on there. As far as the MAP sensor, thats on the throttle body so I'd check and see if the RPM TB has a provision for it.
This picture is from Edelbrock's website showing the TB cable installed on a GSR. I believe the intake manifold comes with a throttle cable bracket (mine for a D16Y8 did).
Re: Edelbrock IM questions...please help out if you can (.dave)
i believe it came pre-drilled holes just not the actual bracket. ill have to check again but thanks for the pictures!
i HAS questions ?
Re: Edelbrock IM questions...please help out if you can (GotRiceYo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GotRiceYo »</TD></TR><TR><TD CLASS="quote">i believe it came pre-drilled holes just not the actual bracket. ill have to check again but thanks for the pictures!</TD></TR></TABLE>
Yeah it comes with holes for mounting a bracket, I'm just not 100% sure if I'm using a stock bracket or if it came with the Edelbrock kit. lol I guess thats what happens when you buy a shell thats missing almost everything.
i have same problem with my im from edelbrock. i need the throttle cable mount have to use a west lake hardware bracket that isnt near strong enough any ideas on how to order the bracket by itself
vtec93accord
03-16-2008 06:06 PM
