help. check engine light, feels like boost cut.
Old Feb 10, 2008 | 05:18 PM
95gsrEG's Avatar
Default HELPPPP!!!!!!!
i have a 95 civic hb si with a b16a2 boosted on 10lbs with a 60trim with 450s....after u drive a lil the cel comes on and if u give it full throttle will in boost it cuts out but if u leave off a lil and get bac on it will go for a lil then do it again..an it loses vtec when it comes on....it has a 255 fuel pump also......any suggestions?????
Old Feb 10, 2008 | 06:20 PM
zex_cool's Avatar
Default Re: HELPPPP!!!!!!! (95gsrEG)
one post per topic please. thanks
Old Feb 16, 2008 | 08:54 AM
a10secstreetcar's Avatar
Sounds like your getting fuel cut and cel light could be a couple of things!
450cc are good for not much more than 300hp I believe. Not sure what your hp is.
Old Feb 16, 2008 | 01:31 PM
boostedcivicsir's Avatar
Mr. Badwrench
ok first off, the thread should be locked because of the title. needs to be more specific. (edited for you)
second, you are in limp mode when the cel is on. what code are you throwing? and why the hell are you goin full throttle boosted with the cel on?
Old Feb 16, 2008 | 02:21 PM
Turbo B18C EJ6's Avatar
Default Re: HELPPPP!!!!!!! (boostedcivicsir)
Are you running on a basemap?
Old Feb 21, 2008 | 03:44 PM
JaredKaragen's Avatar
Default Re: HELPPPP!!!!!!! (Turbo B18C EJ6)
whats your altitude?
moarlow95ex
Jan 16, 2014 04:00 PM
93blulude
Jul 11, 2008 02:41 PM
HmgLauj69
Dec 5, 2007 09:50 AM
743 Stunna
Dec 20, 2004 05:04 PM
civickidd99
Aug 14, 2003 08:29 PM
