Strait T3 setups on a B20?
Old Feb 11, 2008 | 08:59 PM
vestalfootball72
Guest
Posts: n/a
Default Strait T3 setups on a B20?
Well the search doesnt let us search T3, so i have to make a new thread... Im considering using a strait T3 instead of a hybrid on my drag kit. It will be for a B20 bone stock motor. Im looking for quick responce, - any sugestions- im thinkn about this:
http://cgi.ebay.com/ebaymotors...wItem
Old Feb 11, 2008 | 09:41 PM
HiProfile's Avatar
Default Re: Strait T3 setups on a B20? (vestalfootball72)
Well you'd have 10psi before 3k, and that turbo would do 250-300whp if you push it to 15psi and have a good manifold/exhaust.
It will 'die out' as people say, but in this case, torque will drop while HP will still climb. IMO great turbo for a responsive, fast street car.
Old Feb 12, 2008 | 12:42 AM
quicksilver1689's Avatar
i ♥ snails
HIprofile pretty much nailed, it that turbo being smaller in size will reshape the powerband drastically, make it very linear, almost like having a bigger n/a motor with alot of low/mid range boost. what "straight" t3 did you have in mind?
Old Feb 12, 2008 | 06:40 AM
vestalfootball72
Guest
Posts: n/a
I had the one posted in mind--
See, I am not a fan of revving my B20 up high. it simply wasnt made for revvs from the factory-
68 trim wheel, 0.48 a/r ported housing, are the specs--
Thanks for input+
Old Feb 13, 2008 | 08:14 PM
vestalfootball72
Guest
Posts: n/a
any others?
Old Feb 13, 2008 | 08:37 PM
zex_cool's Avatar
t3 with .63 exhaust is small for a d series. why not rev it ? same stroke as b18a/b.
Old Feb 14, 2008 | 04:22 AM
ickyhonda's Avatar
Default Re: (zex_cool)
I put a IHI turbo off of a Murk out of the junk yard on a civic I use to have, same size as t3. It was fun as hell. Low end torque and didn't rev high enough to "fall off." If your not looking to spend alot of money I would buy a junkyard t3 but it is always better to get a decent turbo from the getgo. gt28 wink wink, nudge nudge.
Old Feb 14, 2008 | 06:48 AM
vestalfootball72
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zex_cool &raquo;</TD></TR><TR><TD CLASS="quote">t3 with .63 exhaust is small for a d series. why not rev it ? same stroke as b18a/b.</TD></TR></TABLE>
longevity is a critical part for this build- I daily drive this car and im at college- cant really afford blowing it up...
Old Feb 14, 2008 | 06:51 AM
zex_cool's Avatar
i would worry way more about my tune then my rev limiter if i was you.
Old Feb 14, 2008 | 07:17 AM
project dc2's Avatar
i had a t3 super 60, 100 octane fuel 14 psi hondata/3bar + 440CC injectors
made 262 WHP 254 tq
Old Feb 14, 2008 | 08:23 AM
vestalfootball72
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zex_cool &raquo;</TD></TR><TR><TD CLASS="quote">i would worry way more about my tune then my rev limiter if i was you. </TD></TR></TABLE>
thats probably one of the worst posts I have ever seen. Where anywhere did I say that I was not going to have the car properly dyno tuned?
The car will be setup with 750cc RC injectors, a Walbro 255, B&M FPR, a 3 bar map sensor, and a chipped p28, dyno tuned at RLZ engineering in Concord NC.
Honda did not engineer the B20 to be a rev monster at all, and I intend to keep it that way.
Phil- that looks sick
Old Feb 14, 2008 | 08:24 AM
vestalfootball72
Guest
Posts: n/a
Furthermore what?
Old Feb 14, 2008 | 12:22 PM
Bailhatch's Avatar
Default Re: (vestalfootball72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 &raquo;</TD></TR><TR><TD CLASS="quote">
Furthermore what?</TD></TR></TABLE>
That does not make sense.
I think if you could use a t3 with a .63 housing and 60trim compressor (Tbird if you can find one) and a very good flowing wastegate setup it could be pretty fun in the mid 200s. I can't say I was ever satisfied with that kind of power but some people would be. Also, ditch that fuel pressure regulator, it's just one more thing to **** up on you. I don't see why you would not get a little bigger turbo though. I see you have planned ahead with your injectors. why not the turbo? early power (steep tq rise) on a fwd means wheelspin and wheelspin means slow.
projectdc2, why was that car on 100 octane? dont tell me it was knocking at those power levels. Must have been the worst flowing manifold and exhaust ever and no intercooler or something like that.
Old Feb 14, 2008 | 01:05 PM
vestalfootball72
Guest
Posts: n/a
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">
projectdc2, why was that car on 100 octane? dont tell me it was knocking at those power levels. Must have been the worst flowing manifold and exhaust ever and no intercooler or something like that.</TD></TR></TABLE>
I was trying to figure out how he was saying that i had a D series, when i posted I had a b20 in the title and post?
I ahve a larger 57 trim hybrid, but with the driving I do, Ill never need more than 275hp or so- 250 will suite me fine. The injectors are just one of those things i had laying around from the last setup- I will be using the car on alot of twisties, so im going to tune the power down for dd to like 200whp, with decent tires it should do just fine im assuming. Then a high boost setting if i want to drag- 13 seconds should be pheasible in a 94 si hatch i think
Old Feb 14, 2008 | 01:14 PM
tuner at the time doest like tuning anything on 91 octane more than 12 psi
ramhorn manifold, cca intercooler, tial gate, and ecutout exhaust back then
i think this was back in 2003/2004
now days we're pushing 500 pump 91 pump with no meth
Old Feb 14, 2008 | 07:32 PM
ickyhonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 &raquo;</TD></TR><TR><TD CLASS="quote">13 seconds should be pheasible in a 94 si hatch i think </TD></TR></TABLE>
I had a budget built civic, spent $2500 including car.
92 vx
d16z6
16g (the small one)
450 dsm injectors
basemap on crome
5" skinny winter tires
It ran a 13.6 1/4. If you put a t3 and some radials on, it should be a 13.0 car.
Old Feb 18, 2008 | 09:52 AM
vestalfootball72
Guest
Posts: n/a
Default Re: (ickyhonda)
i am now considering goign a tad bigger- Such as a T3to4b- any suggestions? The t3 super 60 seems to be a little expensive for a small turbo from the looks of it?
Old Feb 18, 2008 | 10:44 AM
i ♥ snails
.83 gt28rs would be sick youd have such a nice fatty powerband
Old Feb 18, 2008 | 12:46 PM
vestalfootball72
Guest
Posts: n/a
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">.83 gt28rs would be sick youd have such a nice fatty powerband</TD></TR></TABLE>
ah i know, but just too much money for me-
im considering a 50 trim borg warner .55ar now that ive spoken with a knowledgable person on the board-
just worried about spool coming in too late, and halfway through a turn, roasting tires and understeering into a tree lol
Old Feb 18, 2008 | 01:24 PM
EASY101's Avatar
* B A N N E D *
just worried about spool coming in too late, and halfway through a turn, roasting tires and understeering into a tree lol</TD></TR></TABLE>
That would only be driver error no matter how you look at it...
Old Feb 18, 2008 | 01:53 PM
vestalfootball72
Guest
Posts: n/a
Default Re: (EASY101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EASY101 &raquo;</TD></TR><TR><TD CLASS="quote">
hm- i guess it could be somewhat, but lets say im acelerating into a strait, and im at 5kRPMS when i hit the turn, and im going through the turn, at the apex begin to accelerate- at 5k acceleration may light up the tires i feel -
well see tho... lol
Old Feb 22, 2008 | 06:48 AM
scrcco's Avatar
T3 spoolin up baby!
Ov3rr3vd3ls0l
Apr 29, 2008 02:17 PM
Mr.Blondie
Dec 4, 2007 12:38 PM
sepetinswenze
Dec 2, 2006 06:04 PM
johnzm
May 26, 2003 12:11 AM
#417R
Dec 11, 2002 11:15 PM
