d15b7 turbo
d15b7 turbo
i have a d15b7
stock block
fully built head
1991 rx7 14b turbo
i have it set at 6.3lbs
wat would be the maximum safe amount of boost that i could run?
stock block
fully built head
1991 rx7 14b turbo
Re: d15b7 turbo (c5stunna)
ok im gonna try and say this before schister beats me to it.
psi will not be your determining factor, a stock motor can only handle a certain increase, most people seem to be comfortable with 220whp-240whp on singlecams, i dont care how much boost it takes to get there, you'll be fine. its power generated that matters not PSI.
What qualifies as a "fully built head" when its a D15B7 head?? Cam'd and ported to the max? Reworked combustion chaimbers and oversized valves?? Sodium-filled valves???
Seriously though, I'd stick to 10 psi based on info given. You'll run the turbo out of breath before you risk floating a valve, if that helps you any. Bu that's assuming you don't snap a toothpick, erm, rod, before anything else. But a boosted d15 is better than limping around NA, I always say.
aleks77
10-22-2008 07:43 PM
0618turbocivic
07-10-2006 06:24 PM
