catch can?
Old Feb 14, 2008 | 03:29 PM
EJ ITO's Avatar
Default catch can?
Ok well here is what I have done to my D16Z6
Skunk 2 cam
Aem Cam gear
Skunk 2 IM
Skunk 2 TB
Cheap Header
Unorthodox Crank Pulley
ACT Clutch
Fidanza Flywheel
My problem is when I am in high rpm, it'd say 6000+ it starts to bog alittlebit. I go take a look and take out the intake and its filled with oil all inside the TB.
So what you guys think, catch can time? Im definetly doing a turbo setup like in 3-4 weeks, got everything I need.
And if yes go with a catch can, where should it come from that you would recommend, like make fittings on the valve cover? If so where towards the intake side or the exhaust side on the valve cover.
Thanks in advance
Old Feb 14, 2008 | 06:09 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: catch can? (EJ ITO)
pm rota92, he had a pretty decent catch can setup for the single cam
Sprockets
Welding / Fabrication
21
Dec 20, 2006 11:54 AM
athoughts
Feb 5, 2005 09:06 AM
Clifton Santiago
Jul 18, 2004 06:00 AM
b20ek
Jun 17, 2003 08:26 PM
skud_dusty
Jul 26, 2002 01:59 PM
