which head gasket for stock turbo gsr
i have searched and found nothing on this. i blew the hg last night while tuning. i need to know what good hg i can get to lower compresion some. my set up is a stock gsr hatch with peakboost turbo kit and my goal is minimum of 300hp with a conservative tune. thanks for the help
Re: which head gasket for stock turbo gsr (mustanggtandgsxr)
Why do you want to lower your compression if your just trying to get 300hp? Can't go wrong with a OEM head gasket with ARP head studs
Re: which head gasket for stock turbo gsr (red_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_crx »</TD></TR><TR><TD CLASS="quote">
just get an oem headgasket....not the ones from parts store</TD></TR></TABLE>
felpro MLS gaskets are just as good as OEM.
Re: which head gasket for stock turbo gsr (CoreyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR »</TD></TR><TR><TD CLASS="quote">
felpro MLS gaskets are just as good as OEM. </TD></TR></TABLE>
my buddy uses the felpro's, but I don't trust them.......just my preferance. Plus I get the OEM ones for cheap
Re: which head gasket for stock turbo gsr (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW »</TD></TR><TR><TD CLASS="quote">Why do you want to lower your compression if your just trying to get 300hp? Can't go wrong with a OEM head gasket with ARP head studs </TD></TR></TABLE>
Yup. That's what I run...
Re: which head gasket for stock turbo gsr (631 Teggy)
well when i pulled my head i saw cylinders 1 2 3 were cracked so ill be starting a 450hp project and i will be using the oem hg with copper. thanks
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustanggtandgsxr »</TD></TR><TR><TD CLASS="quote">well when i pulled my head i saw cylinders 1 2 3 were cracked so ill be starting a 450hp project and i will be using the oem hg with copper. thanks</TD></TR></TABLE>
Ouch!! Who tuned that time-bomb??
Re: which head gasket for stock turbo gsr (Schister66)
i really dont want to say who tuned it but the motor was stock and i didnt know how many miles it had. so i dont know if it was their fault or it was that the motor was already weak. let me know what you think. thanks
Man U FTW
If you would have cracked one sleeve, we could call it a fluke or a bad injector. Two sleeves would have been a little fishy, but all three makes me think that there was something fatally wrong with the tune. I honestly couldn't think of much else that would have let to such a catastrophic failure other than overall fuel cut to the whole engine. I have a feeling that the timing was a little aggressive and the AFR's a little lean....
Man U FTW
Re: (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF »</TD></TR><TR><TD CLASS="quote">for all you know, he could have had a bad tank of gas.. or just run it out of gas in general. </TD></TR></TABLE>
Thats true too...there are a few things that could have caused the problems, but i would still investigate the tune a little bit before attributing it to something else.
Re: (Schister66)
and thats the problem with people these days, they dont know the 1st damn thing about their car... if they did, they probably wouldnt have blown their **** up in the 1st place....
the headgasket is the least of this guys worries.....
Re: (DaveF)
i knew this was going to happen. i knew this motor was not going to last long. thats why i had bought a ge block that i was going to build up little by little, but i guess now im gonna have to build it asap. lol. your right i didnt know anything about my car as i am not mechnically inclined. i have a very good mechanic that knows all this stuff like the palm of his hand. its all fun though when you get into this hobby you know that stuff like this can happen. im not worry about it like i said before ill have a 450hp dd sooner than i thought. its all fun.
Re: (96 GSR-T)
yeah im going to post pics as soon as i get the motor out. i had just pulled the head. i still got to take it out of the car and as soon as i do that all post pics of everything.
Re: (DaveF)
I can't say enough about the OEM head gasket. I used the original head gasket on a motor with 80k and put in ARP head studs one at a time and the motor made 375whp, of course I was when it saw boost for the first time, but it held up fine.
come on guys he said he wants a minimum of 300, i say use a cometic .050" HG, that will drop you down to 9.5 which is perfect imo. ive had boosted high and low compression set ups and i must say i prefer the lower compression set ups, currently 8.3:1 right now on 91 octane 333whp and im not even close to the limit, and thats on cast pistons and stock rods...
Re: which head gasket for stock turbo gsr (blinx9900)
whats your point... we have a car making 390 to the tires on a bonestock ls bottom/bone stock b16 head oh yea,, stock head gasket too !
