Build on my Fully Built b16a EJ1
Old Feb 17, 2008 | 07:51 PM
Turbo Ej1 driver's Avatar
Default Build on my Fully Built b16a EJ1
From Swap to Tune leave comments if u check this out thanks
pics will be up later tonite
Old Feb 17, 2008 | 08:17 PM
Default Re: Build on my Fully Built b16a EJ1 (Turbo Ej1 driver)
Day after i bought it...Head gasket blew and i tried to start it after and i flooded the block
after i towed it to my shop i go 2
Small intercooler
Another small intercooler pic
intercooler change Custom FMIC
Yet another
Old Feb 17, 2008 | 08:19 PM
moores55's Avatar
looks good, more info on it.
Old Feb 17, 2008 | 08:43 PM
Default Re: Build on my Fully Built b16a EJ1 (moores55)
The Build Done by former Motor owner XYZAlvArez
B16 Block:
B16 Golden Eagle Sleeve / Bore 83mm
CP Pistons 9:1 Compression
AEBS Head Studs
Eagle Rods w/ 3-8 ARP Head Bolts
ACL Bearings (Rods)
ACL Bearings (Crank)
AEBS Main Studs
OEM GS-R/ITR Oil Pump
OEM OM Tensioner
OEM Water Pump
Stock Crank
Oil Pan Tapped for Return Line
Vented Block With Honda Plug
PE (Power Enterprise) Timing belt Kevlar
Old Feb 17, 2008 | 08:53 PM
This is the head job
B16 Head:
New Valve Seals
Rev Flat Seal Valves
JG Valvetrain and Retainers
GS-R Cams (for sale or Trade)
Port and Polish Done In a week from now
Eagle Cam Gears
New Vavle Cover Seals
Old Feb 17, 2008 | 09:06 PM
Best way to Race with a Tranny is
LS 1st Gear
LS 2nd Gear
Gsr 3rd gear
B16 4th gear
Ls 5th gear
Thats the way i did it
Old Feb 17, 2008 | 09:41 PM
r1turboed's Avatar
looks nice man.... good luck
Old Feb 17, 2008 | 09:57 PM
Default Re: Build on my Fully Built b16a EJ1 (r1turboed)
Thanks it will be up and running with more pics of swap and and dyno chart
Old Feb 17, 2008 | 11:12 PM
94GSRCivic's Avatar
Interesting tranny setup. I've definately never seen that before. Whats your power goals?
Old Feb 17, 2008 | 11:20 PM
Default Re: Build on my Fully Built b16a EJ1 (94GSRCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94GSRCivic &raquo;</TD></TR><TR><TD CLASS="quote">Interesting tranny setup. I've definately never seen that before. Whats your power goals?</TD></TR></TABLE>
i know i can get mid 300's but im using a smaller turbo for less boost lag and quicker spool si may end up getting high 200's but im doing Road and drag so i was looking into the more all around tranny dont know how its gonna work yet so we will have to see
Old Feb 18, 2008 | 08:00 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Ej1 driver &raquo;</TD></TR><TR><TD CLASS="quote">Best way to Race with a Tranny is
LS 1st Gear
LS 2nd Gear
Gsr 3rd gear
B16 4th gear
Ls 5th gear
Interesting. Subjectively interesting.
Old Feb 18, 2008 | 09:31 AM
ABK's Avatar
ABK
Default Re: Build on my Fully Built b16a EJ1 (TheShodan)
how big of a turbo are you using. That block should be able to hold 400-500hp.
Old Feb 18, 2008 | 02:18 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: Build on my Fully Built b16a EJ1 (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">how big of a turbo are you using. That block should be able to hold 400-500hp.</TD></TR></TABLE>
more than that if he has a big enough turbo
nice setup
Old Feb 19, 2008 | 10:06 AM
Default Re: Build on my Fully Built b16a EJ1 (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">
nice setup </TD></TR></TABLE>
Honestly i dont know yet im still contemplating on which im going to use i have a T3 just for now but i may go gt30 or sc61 dont know yet but i dont want to much bc its still a daily driver
Old Feb 19, 2008 | 10:14 AM
i think i can make alot of power like low 600's or high 500's
Old Feb 19, 2008 | 10:23 AM
Block and head put together block painted blue from last owner and a sponge material vavle cover kinda cool looking
Old Feb 19, 2008 | 05:03 PM
slow96coupe's Avatar
Nice man!!
Old Feb 19, 2008 | 05:39 PM
Drummerboy's Avatar
that gearset is going to be fun.
i have a very similar setup, with LS 1st and 2nd, B16 3rd and 4th, and an LS 5th.
i'm really happy with mine so far. good luck with the rest of the build!
Old Feb 19, 2008 | 06:56 PM
Default Re: (Drummerboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drummerboy &raquo;</TD></TR><TR><TD CLASS="quote">that gearset is going to be fun.
i'm really happy with mine so far. good luck with the rest of the build!</TD></TR></TABLE>
thanks man its gonna take me a little bit to finish some money probs cam through but ill have it all on film so ill make a mini vid or what not and let u guys know and yea a buddy if mine had it on his 900HP civic only ran the tranny once then took it apart bc the season was over so it pretty much good dont know what LSD im gonna run tho but thnks for checking it out so far
Old Feb 19, 2008 | 06:57 PM
Default Re: (slow96coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow96coupe &raquo;</TD></TR><TR><TD CLASS="quote">Nice man!! </TD></TR></TABLE>
thanks man
Old Feb 19, 2008 | 07:09 PM
HondaCivicSiR1's Avatar
Default Re: (Turbo Ej1 driver)
call me crazy but i thought that all hydro b series have the same first gear and that second gear was very close also?
Old Feb 20, 2008 | 12:56 AM
Default Re: (HondaCivicSiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 &raquo;</TD></TR><TR><TD CLASS="quote">call me crazy but i thought that all hydro b series have the same first gear and that second gear was very close also? </TD></TR></TABLE>
Crazy and wrong hahaha but its ok everyone thinks different in ways thats why theres HT lol
ls is similar 2 gsr 1st and 2nd 3 ls really long 4 ls really long 5th well u get the gist
gsr is similar 2 ls like i said 1st and 2nd but third has a good ratio for traction and speed 4 is alright and 5th is ok also
b16 way to quick of RPM jump for first and second 3rd i will still spin and 4 is great if u get traction
thats why i bought this tranny as soon as i saw it up for grabs
Old Feb 20, 2008 | 06:45 AM
TurboEK9Coupe's Avatar
That RA finish on your head looks a little too corse. It should be a pretty smooth finish on there. IMO Did you have the head re-surfaced or did you just scuff it up with a scotch brite pad? Just throwing that out there. But everything looks good. I want to get one of those GE blocks for my car. GL with everything else
Old Feb 20, 2008 | 11:53 AM
Default Re: (TurboEK9Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEK9Coupe &raquo;</TD></TR><TR><TD CLASS="quote">That RA finish on your head looks a little too corse. It should be a pretty smooth finish on there. IMO Did you have the head re-surfaced or did you just scuff it up with a scotch brite pad? Just throwing that out there. But everything looks good. I want to get one of those GE blocks for my car. GL with everything else </TD></TR></TABLE>
It looks corse bc the lighting in the pic its smooth, thanks
Old Feb 21, 2008 | 10:52 PM
just bought an Apexi Vafc wanted to see what u guys thought about that...
