Headgasket sizing
Old Feb 16, 2008 | 04:06 PM
wernhersey's Avatar
Default Headgasket sizing
Hey guys! I am finally beginning to put my motor back together and I need to know how much each mm changes the compression ratio. My motor is a stock b18a1 with a t3/t4. I am shooting for a very reliable 250whp and keep in mind this is my first boost project and I am planning on tuning it my self. Any info would be greatly appreciated. THANKS guys
Old Feb 16, 2008 | 04:15 PM
DaveF's Avatar
Default Re: Headgasket sizing (wernhersey)
use a stock headgasket...
Old Feb 16, 2008 | 04:24 PM
wernhersey's Avatar
Default Re: Headgasket sizing (DaveF)
A stock headgasket will be fine? Would I be better off with a headgasket or are you just saying it will work? Also where is good place to buy turbo gaskets and oil lines. Also can I make my own turbo to manifold gasket out of gasket paper? Thanks
Old Feb 16, 2008 | 04:30 PM
DaveF's Avatar
use a stainless turbo to manifold gasket, most any place that sells parts should be able to get you this.
we use stock head gaskets on our racecars which make 850 + hp and run in the 8's we have never had a headgasket problem...
Old Feb 16, 2008 | 04:39 PM
wernhersey's Avatar
Wow no ****! Thanks man, Is there a good place online to buy oil lines and gaskets from.
Old Feb 16, 2008 | 04:44 PM
DaveF's Avatar
try stealthmode
boostdvic
Oct 20, 2014 11:48 AM
jax97hx
May 30, 2008 12:57 PM
jax97hx
May 29, 2008 10:40 AM
IntegraMastaz
Dec 10, 2005 02:46 PM
1.8T_EG
Sep 12, 2003 07:00 PM
