White Smoke from time to time
Old Feb 17, 2008 | 12:34 AM
sohc_kuhol's Avatar
Default White Smoke from time to time
Is this bad? because i am not experiencing any changes in performance, and i am afraid if i do not take action it will kill my engine in the future.
my exhaust gives out white smoke from time to time, but not all the time. from the beginning my tuner told me its the turbo. what in particular in the turbo? should i get it fixed? what are the cons in ignoring this? are there any other cause for this? TIA
d16 t28,450cc,stock block, stock fuel pump, 9psi
Old Feb 17, 2008 | 11:10 PM
System-7's Avatar
Default Re: White Smoke from time to time (sohc_kuhol)
two things;
turbo seals blown
or
valve stem seals
Old Feb 17, 2008 | 11:11 PM
System-7's Avatar
two things;
turbo seals blown
or
valve stem seals
or valve stem guides
check to see if there is oil in cylinders, oil glaze
Old Feb 18, 2008 | 07:04 AM
sohc_kuhol's Avatar
Default Re: White Smoke from time to time (System-7)
ok thanks! ill get it checked. anymore?
Old Feb 18, 2008 | 08:21 AM
fastcrvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by System-7 &raquo;</TD></TR><TR><TD CLASS="quote">two things;
turbo seals blown
or
valve stem seals</TD></TR></TABLE>
probably none of the above..
white smoke? coolant = probably going under very soon.. suggestion? get coolant pressure check to see where the leak is.. probably nothing you can do at this point except for ease of so it lasts longer
stock block? either sleeves or cracked head..
Old Feb 18, 2008 | 10:45 AM
System-7's Avatar
Default Re: White Smoke from time to time (fastcrvi)
yes smartee pants, everyone may assume coolant right off the bat because it is White, but that does not necessarily mean its coolant, if it is white and smells sweet more than likely it s coolant.
I had blown seals on my turbo and it smoked white, there could be several reasons for this. Oil may at some point burn white, then black if it has been used for a bit. Try putting in fresh oil in a smoking car and see what color it is.
my friends GSX had a blown turbo seals and it burned white, replaced turbo and boom no more white smoke.
I had bad valve stem seals and again it smoked white.
faced!
Old Feb 19, 2008 | 01:23 AM
sohc_kuhol's Avatar
yup im going for this one^^^. i talked to some friends and my tuner and they said the same thanks pal!
Old Feb 19, 2008 | 09:33 AM
maddog20's Avatar
When does it smoke?...in boost/part throttle or is it at idle?
Have you noticed a loss of coolant in the overflow or is overflow filled to the top after a hard run?
Old Feb 19, 2008 | 08:46 PM
sohc_kuhol's Avatar
Default Re: White Smoke from time to time (maddog20)
- Recently i observed the smoking, and it only smoke one time bigtime during my travels. and it let out smoke like hell! only white. not in boost. in part throttle or idle only.
- everyday i go to work which is about 18km from my house. my car will smoke ONE TIME BIGTIME in about 16km when i stop or during part throttle. after a few seconds, no more smoke.
theories guys? TIA
Have you noticed a loss of coolant in the overflow or is overflow filled to the top after a hard run? -sorry for being a noob, but how can i check this?
Old Feb 20, 2008 | 12:00 PM
welfarepc's Avatar
when my car did that... lol... i feel so stupid now... but i didnt realize intake and exhaust valve seals were different... and you guessed it.. white smoke out the *** from the improperly installed valve seals.
learnt that one the hard way
Old Feb 20, 2008 | 01:00 PM
eg:R's Avatar
Default Re: (welfarepc)
how long was the car running untune?
im thinking it can also be piston rings
Old Feb 21, 2008 | 03:58 AM
sohc_kuhol's Avatar
Default Re: (eg:R)
^^ the car is tuned
i guess its the valves seals. but ill also check tomorrow if there are oil in the charge pipes, bec it also might be the turbo.
thanks for the replies
Old Feb 21, 2008 | 08:43 AM
System-7's Avatar
My car smoked similar with a turbo with blown seals, it would smoke at idle, rarely at high speed. check the center section of the turbo to see if oil is coming out. Another suggestion would be to put syntethic and you'll find out if it is the seals on the turbo, that oil can find a leak anywhere.
HOwever, since i've had this problem before, the car smoked when it had bad exhaust valve stem guides which i replaced and boom, no more smoke. good luck
Old Mar 27, 2008 | 09:00 PM
crxzcgoing2boost's Avatar
yeah i have the same issuse with my civic i didnt want to replace the piston rings but i think if it was the rings i would known, ive drove from colorado to new mexico no major issuses ? i think its the turbo valves, or seals
( sorry i dont know that much about turbo just got the car)
there is oil in the intake for the turbo and in the turbo its self,and a light coat in the bov? please tell me its not the piston rings D: ill be sad
Modified by crxzcgoing2boost at 10:06 PM 3/27/2008
Old Mar 28, 2008 | 07:48 AM
flangemastermike's Avatar
im the same ,stock b16, gives a puff of blue smoke when goin on boost , the engines pretty damn old and not had a easy life so i think thats fine, but when i come to a stop in traffic and i dont move for 5mins i get white smoke , other people in traffic always stare. no oil in boost pipes and no loss in coolant. got to be valve seals ?
Old Mar 28, 2008 | 01:51 PM
thx man thats what my preformance shop around here said :D hopefully you and them are right
Old Mar 28, 2008 | 04:53 PM
well this is a sad day found out i riped a piston appart sucks for me ...
oranginal
Apr 28, 2012 05:35 PM
Mikeedubb
Oct 14, 2011 03:57 AM
Lost Type R
Nov 12, 2004 12:34 PM
Hondadrvr215
Oct 15, 2004 10:05 AM
eky2k
Feb 27, 2004 11:45 PM
