thinking bout running e85 need advice
ok I hear u need a 255 at least and bigger injectors...I have 580 now on a stock b20 how much bigger would I need to go..also what kinda power gains and what are some pros and cons....already search just trying to get more opponions thanks
As was previously stated, you need about 30% more fuel than a conventional gasoline setup. If you need help picking the correct size injector, just use 6cc of injector per whp. On E85, you need 7.8cc per whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E »</TD></TR><TR><TD CLASS="quote">3000cc injectors for 500whp...
? You forgot the part about dividing by the number of cylinders....can't forget that.</TD></TR></TABLE>
I thought that portion of it was a given...you need 3000cc of injector for the whole engine, then you divide by the number of cylinders...in our case, 4
? You forgot the part about dividing by the number of cylinders....can't forget that.</TD></TR></TABLE>I thought that portion of it was a given...you need 3000cc of injector for the whole engine, then you divide by the number of cylinders...in our case, 4
There's no such thing as a given on these forums...hahahaha...you know that. If there were things that were a given just think how many less threads there'd be about ebay manifolds....lol.
