best cams for turbo
best cams for turbo
im building a turbo motor.. i have a 2.0 sleeved bottom end.. and a fully bulit head to go with it..
this question goes out to people with 500hp+ motors what cams are you using?
i heard skunk2 are great but i dont know which ones to get
Re: best cams for turbo (gezzuzz)
if you want to be a baller go with pro 1's but you lose alot of drivablity, gsr's and ctr's are a very good all around choice though. both of these cams have made over 600 hp
Mr. Badwrench
Re: best cams for turbo (ShawnR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShawnR »</TD></TR><TR><TD CLASS="quote">u can make plenty over 500 with itrs </TD></TR></TABLE>
made over 500 on gsr's in a b16.
with your 2.0 i would think you would need a bigger cam. the pro 1s are awesome, usinn maz/innes cams over 700 1.9 gsr.
it really depends what you are doing with the car. from my experience, the bigger cams usually raise the power band. i like the gsr's for a street car. the itr's make more power, but loose a little mid range.
Re: best cams for turbo (turbotypeR@SPEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR@SPEC »</TD></TR><TR><TD CLASS="quote">it really depends what you are doing with the car . from my experience, the bigger cams usually raise the power band. i like the gsr's for a street car. the itr's make more power, but loose a little mid range.</TD></TR></TABLE>
I agree. What are your goals? Are you willing to give up drivability and idle for a more aggressive cam? Spending goals?
Re: best cams for turbo (ImaHondaLover)
500+hp daily driven.. i was told by joe alaniz (he built my head) to go with ctr cams.. so that what i plan to do..
I used crowers and my bottom end is sik as hell but I drop off in the top but Im not a drag racer anyway . I would go with the itrs or so if I want to constantly see high rpms.
