Help with turbo size question....
Old Feb 8, 2008 | 11:41 AM
Goinfasterthanu's Avatar
Default Help with turbo size question....
I got a new turbo ... to get rid of the ebay one... My problem is the outer houseing on the intake side says .60 ar where my old one says .50 ar.. Will i need a retune? The wheels are the same size{ .57/.63} on both ......Will 11 psi still be the same 11 psi? Thanks...
Old Feb 8, 2008 | 10:17 PM
blinx9900's Avatar
Default Re: Help with turbo size question.... (Goinfasterthanu)
who makes your new turbo? anyways get it tuned, it will probably be an hour or less of tuning so it wont cost that much...
Old Feb 9, 2008 | 11:46 AM
Schister66's Avatar
Man U FTW
Didn't you already have a thread about this?? I recall one similar if not the same...
Yes you'll need a retune. Anytime you switch turbos and they're different at all, you'll need a retune. That goes the same for switching manifolds, IM's, cams, etc...
cbrodac0424
Jul 30, 2004 12:23 PM
iamthemouse
Aug 18, 2003 11:07 AM
