should i use my stock gsr valves or aftermarket?
hey guys im currently in the process of a turbo build and obviously on a budget, the block is built 82mm,sleeved, etc..... my power goal is 600-650 , my ? is will it be ok/safe to use my Stock gsr valves w/ supertech valve springs and ret. or should i get supertech valves... what would be the benefit if i use the supertech valves...thanks
Man U FTW
You could use the stock valves, valvesprings, etc, but at that power level, you'd be better off running an aftermarket valve train. What cams are you running?? If you're running something aggressive enough, you might not have a choice but to upgrade.
ME LOVE U LONG TIME
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">You could use the stock valves, valvesprings, etc, but at that power level, you'd be better off running an aftermarket valve train. What cams are you running?? If you're running something aggressive enough, you might not have a choice but to upgrade. </TD></TR></TABLE>
he said he's gonna use aftermarket valvetrain..he was asking about the VALVES
Re: (tannerLSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt »</TD></TR><TR><TD CLASS="quote">
he said he's gonna use aftermarket valvetrain..he was asking about the VALVES</TD></TR></TABLE>
are valves not part of the valvetrain? just an honest question not trying to argue...
turboman2.2
07-04-2010 10:08 AM
DC2 Mang
07-17-2006 03:08 PM
