Boost by Gear install***HELP***
I search for a tread on this already but could not find. I wanted to know if there is anyone out there that can provide me a complete diagram on how to properly install the boost by gear controller. Pics of your installs would be great but drawing diagrams will work also. Just want to know the correct sequence or order to install the vacuum lines. Any and all help will be greatly appreciated.
Re: Boost by Gear install***HELP*** (evild16)
if you are using an avc-r here is a link on how to set up boost by gear
https://honda-tech.com/zerothread?id=1037051
Re: Boost by Gear install***HELP*** (urnotfast)
well guess everyone misunderstood my troubles. I actually need to know how to install the boost by gear solenoid. I already have my system setup, Hondatas300 of course, and i have no problems there. I just want to make sure that I hook the vacuum ports correctly to the wastegate and the turbo. Please post any pics of your solenoid install or diagrams you may have to help me. This is the one that i am using.
http://www.t1raceparts.com/Pro...t.htm
hope you didnt pay that much.
fyi; http://www.xenocron.com/catalo....html
you can get them for even cheaper.
anyways, one port goes to the WG and the other to a vac source. jst like any other boost controller.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evild16 »</TD></TR><TR><TD CLASS="quote">well guess everyone misunderstood my troubles. I actually need to know how to install the boost by gear solenoid. I already have my system setup, Hondatas300 of course, and i have no problems there. I just want to make sure that I hook the vacuum ports correctly to the wastegate and the turbo. Please post any pics of your solenoid install or diagrams you may have to help me. This is the one that i am using.
http://www.t1raceparts.com/Pro...t.htm</TD></TR></TABLE>
if you look under the help/ contents file there is a boost control solenoid installation diagram
