stock sleeves
Old Feb 12, 2008 | 03:16 PM
b16bri's Avatar
Default stock sleeves
Hey guys, whats the hightes boost level you guys would run on stock sleeves ? Ive read a lot of things here on HT, about boost is irrevelant it's horsepower that matters. I know b16 sleeves are good to about 500hp, which is more than i need i'm hoping for 400whp btw. The reason I ask is i have a stock sleeved fully built b16 with a block guard, and 2 different performance shops have told me not to run over 15-16psi and the guy who did all the bottom end building/ machine work guaranteed me i can run 18-20 with no problem. I want to run 18-20 and i'm just about to get it tuned what do you guys think is safe for stock sleeves
Old Feb 12, 2008 | 03:21 PM
DA_HONDA_BOY's Avatar
Default Re: stock sleeves (b16bri)
ppl making over 700+whp on stock sleeves with over 25+ psi of boost
psi don't mean explative
Old Feb 12, 2008 | 03:37 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: stock sleeves (DA_HONDA_BOY)
over 700 on stock sleeves for a little while maybe.
and he is right about the psi not the issue.
my friend made 600 on stock sleeves fir 1 dyno run, then went boom.
at that level, any hiccup is usually catastrophic.
Old Feb 12, 2008 | 03:56 PM
b16bri's Avatar
Default Re: stock sleeves (boostedcivicsir)
understandable but a hickup can happen on 15 or 20psi or even lower and i understand thats were a good tune comes in i just want to make sure that 18-20 psi and 400whp whont be to much stress on my motor
Old Feb 12, 2008 | 04:33 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
https://honda-tech.com/zerothread/2223593
Old Feb 12, 2008 | 05:38 PM
PHDZINE's Avatar
Default Re: (tannerLSt)
It's all in the tune...as long as you run moderate boost.
Old Feb 12, 2008 | 07:39 PM
dc2turbo's Avatar
Default Re: (PHDZINE)
18-20psi with what turbo?
Old Feb 12, 2008 | 08:45 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (dc2turbo)
PSI is too relative to matter across the boards, son.
Old Feb 13, 2008 | 05:42 AM
tegman23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2turbo &raquo;</TD></TR><TR><TD CLASS="quote">18-20psi with what turbo?</TD></TR></TABLE>
X2 it depends if your going to run 18-20psi on a stock 14b or a gt35r... psi really doesnt matter
Old Feb 13, 2008 | 12:18 PM
b16bri's Avatar
Default Re: (tegman23)
the turbo is a garret t3/t04e 57 trim and a full-race mani if that matters
Old Feb 13, 2008 | 12:26 PM
Schister66's Avatar
Man U FTW
Default Re: (b16bri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16bri &raquo;</TD></TR><TR><TD CLASS="quote">the turbo is a garret t3/t04e 57 trim and a full-race mani if that matters</TD></TR></TABLE>
On an SLS ramhorn w/ a 57 trim and 110 octane, SLS's white hatch made 451.9whp at 24psi on a piston/rod/stock sleeve setup w/ a B16. Then proceeded to run a 10.47
Old Feb 13, 2008 | 02:41 PM
skotsephrenia's Avatar
Why not spend a little bit of cash for an after market sleeve which at the end of the day will give you a peace of mind.
cheers..
Old Feb 13, 2008 | 07:00 PM
FRernesto's Avatar
Default Re: (skotsephrenia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skotsephrenia &raquo;</TD></TR><TR><TD CLASS="quote">Why not spend a little bit of cash for an after market sleeve which at the end of the day will give you a peace of mind.
cheers.. </TD></TR></TABLE>
I have my GSR with only rods and pistons for over 2 years boosting 25lbs making well over 500whp and no issues. For stock sleeves good tunner and C16
Briang3a3
Jan 17, 2008 04:10 PM
b20vtech
Oct 2, 2007 02:14 PM
ttracing03
Apr 1, 2006 02:43 PM
B18 CYA
Apr 7, 2004 03:43 PM
itr1236
Mar 10, 2002 05:18 PM
