helpppppppppppp!!!!!!
Old Feb 10, 2008 | 06:02 PM
95gsrEG's Avatar
Default helpppppppppppp!!!!!!
i have fixed the boost problem by putting a new harness on and it no longer cuts out and its runnin good but has no vtec still and is throwing code 9..and also it has a resistor box on now..tdc code is comming up?....and sry for b4...
Modified by 95gsrEG at 7:27 PM 2/18/2008
Old Feb 10, 2008 | 06:04 PM
slooogsr's Avatar
I would say......... take it back to your tuner........
Old Feb 10, 2008 | 06:07 PM
95gsrEG's Avatar
Default Re: (slooogsr)
it does it sumtimes then sumtimes it wont...
Old Feb 10, 2008 | 06:18 PM
zex_cool's Avatar
injectors going bad. wiring, ground, power supply and etc.
Old Feb 10, 2008 | 06:32 PM
95gsrEG's Avatar
Default Re: (zex_cool)
do black top dsm 450 injectors need a resister box???
Old Feb 10, 2008 | 06:33 PM
Schister66's Avatar
Man U FTW
You could be spiking a little bit which would cause the map sensor to throw a code; therefore, putting your car into "limp mode." I would take it back to a tuner and have he/she make the analysis of the problem...it sucks, but that's probably your best bet.
Old Feb 10, 2008 | 06:34 PM
japan4racing's Avatar
pull the cel's and find out what is stored then report the code to us. what is telling you that you run 10 psi...that shitty autometer guage or was off a datalog? autometers are nto the best hting and can be off. youm ay be running more and you map sensor is pissed at you!
Old Feb 10, 2008 | 06:41 PM
95gsrEG's Avatar
Default Re: (japan4racing)
yeh i have auto meter lol but i will do that
Old Feb 10, 2008 | 07:15 PM
zex_cool's Avatar
yes, all dsm 450cc injectors require resistors/resistor box.
Old Feb 10, 2008 | 07:30 PM
95gsrEG's Avatar
them not having that would cause it to do that?
Old Feb 10, 2008 | 07:31 PM
H.A.R.T B18C1EG6's Avatar
Default Re: (95gsrEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrEG &raquo;</TD></TR><TR><TD CLASS="quote">do black top dsm 450 injectors need a resister box???</TD></TR></TABLE>
yes and are you using one?
Old Feb 10, 2008 | 07:37 PM
95gsrEG's Avatar
Default Re: (H.A.R.T B18C1EG6)
no it dont have one on it...and that would cuase vtec to not at times also?
Old Feb 10, 2008 | 07:44 PM
that wont effect vtec but dude..you gotta fix that. they require a resistor for a reason. the only things that can effect vtec are low oil pressure, cold oil temp, or if you get an open for either the rpessure switch and/or the solenoid. i have never heard of an obd-1 car going into limp mode. i have had some serious probs with cars before and my hondas have never gone into limp mode.....however if the map sensor is expletiveed your car will suck at life.....and you will think its in limp mode!!!
vtec_killer_'s Avatar
Are u running a stock map sensor? if so, u are getting that check engine light probably from that when u hit boost. If so, run some fish valves or get a missing link. U could overheat and smoke your ecu out if u dont use a resistor box with those injectors. I think there is a video on Hondata.com about that.. check it out. good luck
Old Feb 10, 2008 | 07:45 PM
zex_cool's Avatar
its not your mad vtach y0 ! its your fuel.
go to radioshack and pick up some 10omh 10w inline resistors and wire them in on the yellow/black injector wires. or find a write up on how to do the resistor box.
Old Feb 10, 2008 | 08:01 PM
95gsrEG's Avatar
i had a 93 si that had wiring problem that made vtec not work and that might be the problem here but the hole cuttin out thing is still shitty as hell and this cars a pain in my ***.. damn hondas
Old Feb 10, 2008 | 08:12 PM
zex_cool's Avatar
i take donations.
Old Feb 10, 2008 | 09:13 PM
Evilparadize's Avatar
Try fixing your spelling! Check your injectors or your A/F ratio.
Old Feb 11, 2008 | 02:25 AM
93supercoupe's Avatar
Default Re: (Evilparadize)
has anybody confirmered this thing is tuned t all?
If it is tuned, ur probably hitting ur boost cut.
If its not, u shouldnt be driving the car anyways.
If u ask me, its not tuned at all.Thats just a gues tho.
Old Feb 11, 2008 | 06:25 AM
daveedd357's Avatar
Default Re: (93supercoupe)
Probably not hitting boost cut, probably a lean pop causing that. yikes
Old Feb 11, 2008 | 06:30 AM
tegman23's Avatar
Default Re: (daveedd357)
It must not be tuned, because any good tuner would see those injectors and tell him he needs a resistor box ...what ecu and managment are you running?
Old Feb 11, 2008 | 04:34 PM
95gsrEG's Avatar
could a wiring problem under the dash cause any of this ****??
Old Feb 11, 2008 | 05:26 PM
sirtef9's Avatar
Check for a loose "Nut" behind the wheel!
Old Feb 11, 2008 | 05:31 PM
roachsboosted16's Avatar
Default Re: helpppppppppppp!!!!!! (95gsrEG)
it sounds like i have the same problem but my friend tells me its ignition, but i thinkits wastegate
Old Feb 12, 2008 | 07:52 PM
95gsrEG's Avatar
Default Re: helpppppppppppp!!!!!! (roachsboosted16)
i hate cars!
