Searched: Need engine builders help!!!!
Old Feb 16, 2008 | 12:07 PM
19slocivic97's Avatar
Default Searched: Need engine builders help!!!!
Like titile says, I need to know what you guys think about what I should set my piston to wall clearance at. The set up is 81mm gsr(stock sleeves) using wiseco 8:1 pistons,t3/t04e. I would like to make close to 350-380 whp. Wiseco spec sheet says .0025. I've read some guys running .003-.004 so I'm not quite sure where to have it set at. Also I plan to dd
thanks
Old Feb 16, 2008 | 12:55 PM
champLSinteg's Avatar
Default Re: Searched: Need engine builders help!!!! (19slocivic97)
Do not go with .0025. I made the mistake of going with their recommended clearance and I cracked a piston when I slightly over heated. In my new rebuild I went with .004 clearance on CP's but I would go at least .0035 with the wiseco's.
Old Feb 16, 2008 | 04:15 PM
Default Re: Searched: Need engine builders help!!!! (champLSinteg)
thanks for the info, anyone else?
Old Feb 16, 2008 | 04:19 PM
DaveF's Avatar
4.5 thou " piston to wall" as a minimum
so far its working great... this same engine had been in a 450hp pumpgas street car, an 800 hp race car(over 25 dyno pulls, and 6 track pass's) then put into my friends car, and went 8's @ 165. now its sitting on the floor waiting to be refreshed, and everything still looks sweet, the cross hatch is there, no scuffing... what more can you ask for ?
Old Feb 16, 2008 | 05:00 PM
Default Re: Searched: Need engine builders help!!!! (DaveF)
thanks for the info davef, do think .0045 would be the min. or do you think I could go with .0035. Also does .0045 give you any piston slap?
Old Feb 16, 2008 | 05:14 PM
DaveF's Avatar
slight piston slap. barely anything.... al hell of alot less than say a 55 thou piston to wall.
dont do .45 thou either, that is death.
RACEPAK
Aug 12, 2008 06:54 AM
Robin.
May 20, 2008 07:27 AM
19slocivic97
Feb 19, 2008 06:55 PM
drumking15
Jan 10, 2005 10:09 AM
Cyber ITR
Jan 29, 2004 09:48 AM
