turbo ls b18b sotck internals
* B A N N E D *
is it safe? getting a b18b from hmotors
is it safe to boost on stock internals?
if so, how many pounds? whats the whp range? thanks.
Re: turbo ls b18b sotck internals (Jtuned DC2)
Yes, it's safe. A compression test and general tune up should be performed. As far as the power limit, that will vary and can't really be estimated. If you're building a racecar, I would hope you would be building a race engine. Tune it well to 250-300 and you'll be living life.
is it safe? getting a b18b from hmotors---bought engines from them.
is it safe to boost on stock internals?---yes, if done correctly.
if so, how many pounds? whats the whp range? thanks.---can't remotely answer this until the setup is stated. I'd say an average of 250whp on stock ls engines usually with nice torque numbers.
Jtuned DC2
11
02-07-2008 07:48 PM
