EK with B20b and t3/t4 and dsm's
seems like my dsms are soaking my spark plugs. this is without using my adjustable FPR. was wonderin what fuel pressure anyones using with these. also i have a set of 275's. should i use these until i get my car tuned or turn down the fuel pressure for my DSM's
Re: EK with B20b and t3/t4 and dsm's (rwlangdale)
does the ecu have a basemap for the 450's? if not then thats gonna be your problem. you will run rich. i would suggest getting it to a tuner. dont worry about messing with the fuel pressure or anything like that. if necessary use the stock injectors and ECU and then reinstall the upgraded stuff at the tuner
Re: EK with B20b and t3/t4 and dsm's (dpetro1)
yeah it has a base map for the 450's. i included that in there special instruction part...
turbosijuice
02-11-2006 09:14 AM
