SRP pistons ????
Old Feb 10, 2008 | 09:19 AM
boostedb20z's Avatar
Default SRP pistons ????
ok i got a set of srp pistons and i need new rings and i have on hand a set on 81.5mm rings oem honda ones and i was wondering what you guys think about useing the oem ones with srp's and another thing is all the motors i have built the pistons have had a arrow marked on the top of the piston to tell you what way to install them but the srp's dont so if somone could help me out thanks.
Old Feb 10, 2008 | 12:38 PM
boosstboy's Avatar
Default Re: SRP pistons ???? (boostedb20z)
i thought honda only made up to .25mm over bore rings. anyways get je rings the groves will be a different size and material a different expassion rate, a forged piston is different from a stock piston. the way to tell the piston position is valve reliefs in the piston top.
EKJOE
15
Mar 31, 2009 07:42 PM
boostedb20z
Feb 10, 2008 05:35 PM
b20vtech
May 10, 2007 06:23 PM
99B16Si
Dec 25, 2002 08:39 PM
