Wastegate problem!
Old Feb 15, 2008 | 01:44 PM
steveop's Avatar
Default Wastegate problem!
I have a 92 turbo civic DX hatch. its a t3 turbo obx-r ram manifold. no name wg. when i bought the car the kid had a 7lb spring inside. but the car just kept spooling to the point where it started to cut out.. like 12-14 lbs. so i thought it was a junk no name spring so i bought a Tial 8.7 lb spring....just installed it and still the same. vacuum line from turbo to wastegate is good. so what could it be causing wg to not dump?
Old Feb 15, 2008 | 02:49 PM
a10secstreetcar's Avatar
What type of boost control are you using?
Old Feb 15, 2008 | 03:15 PM
ctr83's Avatar
Default Re: (a10secstreetcar)
he using the wg spring by the sounds of it.
Old Feb 15, 2008 | 10:44 PM
TIGboy's Avatar
Default Re: Wastegate problem! (steveop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveop &raquo;</TD></TR><TR><TD CLASS="quote">I have a 92 turbo civic DX hatch. its a t3 turbo obx-r ram manifold. no name wg. when i bought the car the kid had a 7lb spring inside. but the car just kept spooling to the point where it started to cut out.. like 12-14 lbs. so i thought it was a junk no name spring so i bought a Tial 8.7 lb spring....just installed it and still the same. vacuum line from turbo to wastegate is good. so what could it be causing wg to not dump? </TD></TR></TABLE> it could be stuck, do you have the firing ring installed?
Old Feb 16, 2008 | 07:50 AM
steveop's Avatar
Default Re: Wastegate problem! (TIGboy)
fire ring is installed..so my buddy told me my vac line is good...but i really think thats the prob. he had 2 pieces of line running from turbo to wg. connected with a really tiny connector and then no fitting on the wg ...he was using a banjo bolt...im guessing this is restricting the air causing the wg to only see maybe 4-5 lbs when the turbo is seeing 8-10?
Old Feb 16, 2008 | 08:45 AM
ctr83's Avatar
that banjo bolt come whit the wg if it tial so i would be alright.
Old Feb 16, 2008 | 03:12 PM
toddone's Avatar
Check the diaphram inside the wastegat. I have seen it a few times on ebay wastegates. the vaccuum port bolt goes in too far and puntures the diaphram. hope this helps
Old Feb 17, 2008 | 12:51 PM
steveop's Avatar
Default Re: Wastegate problem! (toddone)
thnks everyone... bad diaphram, ordered new TiAL today.
R.A.T.
Oct 8, 2008 06:53 AM
boostedf22cd5
Oct 10, 2006 09:30 PM
LilCivic04
Jul 12, 2005 10:25 PM
19sec beast
Jun 2, 2005 08:29 PM
dc2pffsssttt
Mar 8, 2003 08:54 PM
