How to solve overheating after 2 hrs of running hard?
How do you solve overheating after running hard for 2 hrs?
I have a 99 Civic w/Greddy Turbo on a B16Y8. After about 2 hrs of running hard (up to 15psi, w/cooling fan manually set at ON) my car starts overheating, not too bad but once it goes 3/4 up on the stock gauge I slow down and everything is fine.
I thought of replacing the radiator w/ a Fluidyne @ $399.95. Is there any other radiator that would fit and give me more capacity than the stock 4.2 L and more cooling area. Maybe an Integra radiator? Does anyone have a set-up they really works for them?
Please give info and facts from YOUR actual experience, if possible. Money not an issue, I really want something that works great.
Thank you in advance for all input and suggestions.
Re: How to solve overheating after 2 hrs of running hard? (00SilverLS)
Maybe you shouldn't be running your car hard for 2 hours.
I'm pretty sure you can fit an integra fluidyne in there. May take some modification/fabrication for brackets to hold it in place.
Dustin
Dustin
Re: How to solve overheating after 2 hrs of running hard? (dustin)
if youre running 15psi Im assuming youre already intercooled. A larger radiator would definately help. A more efficient fan would be nice also, like a FAL fan. Also an oil cooler would be another good investment.
Re: How to solve overheating after 2 hrs of running hard? (GReddySetGO)
running ur car hard for 2 hours?! i hope u ready for a rebuild... get a fluidyne and a cheap pep boys fan and put it on it (u dont need the overpriced fal stuff)
I forgot to also state that the complete ac system has been removed therefore, I do have the space for a bigger radiator.
Someone told me that a stock Integra radiator would fit and does work well, does any of you have this set-up?
Re: How to solve overheating after 2 hrs of running hard? (civicturbo)
be ready for another headgasket coz your'e gonna need it......
while your in there have the cylinder head check for warpage....
i suggest to get new head bolts and learn to boost low next time.....
it doesn't matter if you get fluidyne rad. and a big fan... if your ain't tune right and mix it with too much boost something is gonna blow and in your case it's your head gasket.......peace.
Re: How to solve overheating after 2 hrs of running hard? (jjgotboost)
Anyway, my question as stated on the original post was, if anybody has a Fluidyne or an Integra radiator and how do they like the set-up, not what's causing the higher temps.
The higher temps are normal on highly modified cars like mine. That's why you will never see a stock radiator on a true race car. The cooling surface and capacity(4.2L) of the stock radiator are not enough.
The website address provided by JCushing has real good info and I would like to thank him along with everybody else that took the time to respond.
For those interested there is a similar topic under "Which radiator for Turbo" dated 01/20/2002 which has a great deal of info too.
Re: How to solve overheating after 2 hrs of running hard? (JCushing)
I would try replacing the thermostat with a lower temp one like the one from mugen or any of the other brands you prefer, I think your stock radiator should be able to keep up.
My friend got a civic flyidine radiator and one fan on his turbocharged B18C1 teg and it keept the car pritty cool...
Adi
