how much power for my setup ?
Old Jan 21, 2002 | 03:26 AM
Cyber ITR's Avatar
Default how much power for my setup ?
stock JDM B18C ( 10.6:1 CR )
garrett T28 @ 6psi
custom intercooler ( 600x300x76 )
full standalone Link computer
550cc x 4 injectors
Tial external wastegate
BLiTZ DD BOV
some unknown fuel pressure regulator
is it worth it to bore out the throttle body ??
opinions please
thanks
Old Jan 21, 2002 | 08:13 AM
b18bturbo's Avatar
Default Re: how much power for my setup ? (VTEC_SiR)
thats a little two small turbo but you can get instant response it will be nice on the street but it will definitely not flow where it needs to be. you should push at least 200 to the wheels with 6psi hopefully. TB boring will jsut help you a little but not much.
Old Jan 21, 2002 | 08:21 AM
ArizonaTurbo's Avatar
garrett T28 @ 6psi
550cc x 4 injectors
BLiTZ DD BOV
opinions please
thanks
I have seen Garrett T28's push 280-285 whp @ 16-18 psi. Keep in mind the outlet air temperature from the compressor is very hot at these levels. I am not too sure what the exact specs are on your T28, but if it is a fairly large T28, you should be able to make that power with your setup conisdering you have the fuel and the bottom end holds. It will be a very quick spooling street car!
Old Jan 22, 2002 | 01:16 AM
Cyber ITR's Avatar
Default Re: how much power for my setup ? (b18bturbo)
oh yeah i got 2.5" downpipe and full 3" exhaust system
the turbo is off nissan pulsar GTiR
thanks
[Modified by VTEC_SiR, 10:17 AM 1/22/2002]
Old Jan 22, 2002 | 06:19 AM
BoM's Avatar
BoM
over 200 hopefully, but never over 300
Old Jan 22, 2002 | 08:50 AM
Type-ARR's Avatar
Default Re: how much power for my setup ? (BoM)
Looking at about 750-1000 HP with that set-up not sure it will be street legel.....j/k
I say around 250hp or so....
Old Jan 22, 2002 | 09:19 AM
Cyber ITR's Avatar
Default Re: how much power for my setup ? (TurboR481)
i just wanna get 170kw@wheels ( 227 whp )
then ill be happy
ehhhe
thanks, u guys are the bomb
akira712
Nov 5, 2006 03:26 PM
RACEPAK
May 29, 2005 07:24 AM
stoopid_monkey
Apr 2, 2005 03:23 AM
bboyoxygen
Jan 8, 2005 06:11 PM
Suprdave
Jul 15, 2001 11:59 AM
