what ecu to run?
Old Jan 19, 2002 | 02:40 PM
11secdx's Avatar
Default what ecu to run?
my friends got a 92 hatch with a 96 gsr motor and turbo. runs great, but throws alot of codes. he has a odbII ecu, with one o2 sensor right behind the down pipe.does he need to swap to a odbI ecu? if he does, does he need to swap anything else out besides the ecu to make it run right? please help, thanks
Old Jan 19, 2002 | 02:47 PM
sgT's Avatar
sgT
Default Re: what ecu to run? (11secdx)
get a 94-95 gsr ecu and make sure all the extra wires have been added.
Old Jan 19, 2002 | 03:43 PM
threatcon13's Avatar
New User
Default Re: what ecu to run? (sgT)
he'll need an obd1 p72 ecu like sgt said, and an obd2 to obd1 jumper harness.(available from hondata or skunk2)
Old Jan 19, 2002 | 07:48 PM
11secdx's Avatar
Default Re: what ecu to run? (turbo01gsr)
so besides the obd1 ecu and a jumper harness, it should plug in and run fine, right?
Old Jan 19, 2002 | 07:54 PM
sgT's Avatar
sgT
its a 92 civic. he wont need the harness.
you just have to make sure the vtec, and other things are wired up.
Old Jan 19, 2002 | 08:02 PM
11secdx's Avatar
the car runs great. vtec works fine. but the ecu throws codes # 1, 10. just more often than he would like. sometimes it goes to safety mode, but most of the time it don't. any suggestions? thanks
Old Jan 20, 2002 | 10:41 AM
11secdx's Avatar
tt
Old Jan 20, 2002 | 10:51 AM
sgT's Avatar
sgT
code 1 = primary O2 sensor unplugged
Code 10 = defective/unplugged IAT(air temp) sensor.
check those out.
Old Jan 20, 2002 | 12:08 PM
miller's Avatar
just buy a DFI it will solve all your problems
Old Jan 20, 2002 | 09:37 PM
11secdx's Avatar
i checked all his sensors, they looked alright, and were plugged in. so do ya'll think if i changed ecu's it might cure his code problem?
[Modified by 11secdx, 6:38 AM 1/21/2002]
BoostJockey
23
Feb 7, 2014 04:42 PM
rhd98civic
12
Jan 15, 2010 11:21 AM
shytdoode
May 20, 2009 03:41 PM
mx621
Oct 27, 2005 01:48 PM
af97civic
Jan 5, 2004 08:31 AM
