turbo B18B
I have an eg hatch witha B18B ls engine. I want to go with the drag 3 turbo kit. Does anyone have any idea of the whp that it will make withjust the basic kit? How reliable is this setup? Anthing else that I should order with the kit?
very reliable easy 200hp dynoed with 8psi you can even go run 10 psi safely if you just a get little larger injectors and tune the fuel pressure right. With the low compression of the ls its awesome daily driver.
