Does everyone have a gasket between turbo and manifold or no? Necessary?
Re: Does everyone have a gasket between turbo and manifold or no? Necessary? (Arturbo)
I have a gasket for it, better to be safe then have a leak!
[Modified by 97CivicFerio, 1:49 PM 1/19/2002]
Re: Does everyone have a gasket between turbo and manifold or no? Necessary? (Blown90hatcH)
So i guess its not necessary! Just debating on whether to get one or not.
Re: Does everyone have a gasket between turbo and manifold or no? Necessary? (TurboDC2)
I personally would get one, just to be on the safe side. Every factory turbo car that I know of has one there, so there is no exhaust leak. Better to be safe than sorry. Later!
New User
Re: Does everyone have a gasket between turbo and manifold or no? Necessary? (00SilverLS)
Got high temp gasketmaker in there.
Re: Does everyone have a gasket between turbo and manifold or no? Necessary? (5gen-hybrid)
Heck as cheap as they are why not. Only cost about 4 bucks from autozone or o'rilleys. 89 thunderbird. So yeah.. I got one!
be careful with that stuff because it usually won't hold up for very long.I tried using that stuff when i sealed off the external wastegate flange and it started to leak after a while.The stuff i used was ultra copper high temp gasket maker that is good for up to 700 degree's i think.
New User
Re: Does everyone have a gasket between turbo and manifold or no? Necessary? (Strng1dah)
i dont have one...i called turbonetics before i put my turbo in and they said its not necessary...but i guess its better to be safe than sorry, will probably get one after my car is tuned.
New User
nissan makes a real nice multi layer gasket. out of an 84 300zx turbo. costs about 18 bucks if i remember correctly.
New User
Damn where did you find that stuff? i looked for months and the highest temp i could find was 750 degrees and that wasn't rated for a constant 750 degrees like the manifold would exceed for extended periods.So i had to settle for the 600 degree or so.What is the brand name so maybe i can pick some up (or order it).
I have one..
Unless the manifold and turbo housings are freshly planed you prolly will get a small leak without one.
They make the gaskets for a reason.....
wickedxboi
02-07-2003 11:22 AM
