Supercharger How-to?
Old Jan 20, 2002 | 06:31 AM
B16A1-EF9's Avatar
Default Supercharger How-to?
Does anyone know the install procedure for the Jackson Racing supercharger on b16a1's?
The reason I ask is, JR has a kit for the b16a2 which I ordered already, but I have a b16a1...will there be any problems with installing this kit? I heard that the b16a2 crank pulley is different then the b16a1 pulley, is this true...if so will I have to change them for boost and belt issues?
What else will I have to do to get this kit working with my b16a1? The stock boost will be at what point, anyone know? If there is a difference between the b16a1 and a2 pulleys I know that the boost will be different awsell, but asuming that it's used with a b16a2 pulley, what boost will I be running 6 psi????
Also, should I get underdrive pulleys? If I do, this will cause my boost to go higher right? But I heard the Honda motors don't like the underdrive pulleys because of the oil pump and vibration and also because of the alternator not spinning fast enough to pump 14.7 volts? Is this all true, any help is apprecited!
[Modified by bandit_sir, 10:41 AM 1/20/2002]
Old Jan 20, 2002 | 06:36 AM
B16A1-EF9's Avatar
Default Re: Supercharger How-to? (bandit_sir)
One more question, should I run an electrical water pump instead of the factory belt driven, does any company make a kit for b16's?
LUKE 92 GS-R
Aug 21, 2012 04:14 AM
Gsr4Life
Mar 22, 2006 11:33 AM
DDD
Oct 7, 2003 08:44 PM
