any one broken a piston or blown a head gasket
i did a leak down cyl 4 only 75% leaking in to crank case .I dont know if piston or gasket cause car only idles rough at speed cars smooth and is only down 35hp I have broken pistons and lifted ring lands before and never ran as good but never popped a v-tech before. If its a gasket I'll do on the week end if piston goin drive it til i can to ahole motor
[Modified by spoolin342, 3:34 AM 1/19/2002]
Re: any one broken a piston or blown a head gasket (spoolin342)
you can tell if its the head gasket because you will see the coolant bubble when you take the cap of the radiator(if its only a bad compression test on one cyl) sounds more like broken ring lands to me. is there any smoke from the breather?
turbod16y7vtec
11-10-2002 03:51 PM
