need Missing Link valve
Old Jan 22, 2002 | 03:14 AM
tarkus's Avatar
Default need Missing Link valve
Looking for the cheapest source for Missing Link MAP bypass valve.
Import parts wants $65 (good price?)
Please email response directly to...
keith.brou@sympatico.ca
Old Jan 22, 2002 | 05:56 AM
ekb18c's Avatar
Default Re: need Missing Link valve (tarkus)
i have been hearing about this "missing link". What the hell is a missing link? And why are so many people using it? Correct me if I'm wrong, but isnt a missing link jsut some device that some company made so the computer wont read boost? If thats the case then why dont you just use a couple of whisper2000 check valves from your local pet store. Why spend $65 dollars when you can get the same thing with 20 dollars at most. ($2.50 per check valve at a pet store) and a dollar something for a couple of T's.
Old Jan 22, 2002 | 06:29 AM
karmannghia's Avatar
Default Re: need Missing Link valve (ekb18c)
Would you rather have couple of plastic valves controlling your investments? Or would you rather have a metal encased missing link bypass? Besides it's suppose to be smoother in the transition.
Old Jan 22, 2002 | 06:59 AM
ekb18c's Avatar
Default Re: need Missing Link valve (karmannghia)
smoother transition? what thats suppose to mean? Check valves does the same damm thing as the missing link, and i hear some people are having problems with the missing link. Just cause it has some metal casing doesnt mean its works better. hahahah.. Missing link is a check valve inclosed in some fancy metal casing. But its up to you. Pay 70 dollars for some metal casing or a 10 dollars for something that does the same damm thing.. Up to you, its your money.
Old Jan 22, 2002 | 07:16 AM
ken's Avatar
ken
https://honda-tech.com/zerothread?id=116600
Selling mine for $40+sh. Used.
Old Jan 22, 2002 | 09:30 AM
4dGSR at work's Avatar
Default Re: need Missing Link valve (ken)
I'LL SELL MINE FOR 40 PLUS SHIPPING TOO
PICK A COAST!!!
HAHAHA
SPEND 25-30 BEANS ON CHECKS OR THE LINK.. YOU PICK!
Old Jan 22, 2002 | 09:39 AM
PROFILES2000's Avatar
Default Re: need Missing Link valve (4dGSR at work)
to me the missing link was just a cleaner alternative to messy check valves ive seen some real nasty looking check valve installs
Old Jan 22, 2002 | 09:54 AM
dustin's Avatar
The cheapo aquarium check valves do not handle boost or engine temps too well. I have had them fail.
They also do not like to stay attached to vacuum lines.... Ever had your vacuum lines fall off your cheapie check valves while driving? It's great to have your car not run and have to get out and fix it.
Dustin
Old Jan 22, 2002 | 10:09 AM
ekb18c's Avatar
Default Re: need Missing Link valve (dustin)
well its all about the install on the check valves. What i do is:
I tee off the vac line before the map sensor and put 3 check valves in. then I zip tie those check valves in. (so they dont fall out). Call me ghetto, but I rather waste my money on other things.
Old Jan 22, 2002 | 11:08 AM
dustin's Avatar
All I know is that my car is wayy smoother with the missing link.
Dustin
Old Jan 22, 2002 | 11:09 AM
Rob03Pro5's Avatar
If you cannot find a Missing Link, simply buy an aluminum industrial strength check-valve from Earl's Fittings.
Old Jan 22, 2002 | 02:05 PM
Projekt20's Avatar
Default (Ken) I'll take them!
Email me.
-Trung
Old Jan 22, 2002 | 05:49 PM
turbopanda's Avatar
Default Re: (Ken) I'll take them! (Projekt20)
I don't connect any "missing link" or check valves to my map sensor at all. I just have this nifty little device called a ClampLink which sends the real map signal to my Link ECU, and sends a modified 0 vaccuum signal to my stock ECU so that it knows that its at full throttle, but doesn't see boost. That works better than ANYTHING else mentioned above. And i'd like to see how check valves are able to handle high boost (anything over 1 bar)
Old Jan 22, 2002 | 07:06 PM
ekb18c's Avatar
Default Re: (Ken) I'll take them! (nathan's boosted civic)
Check valves wont handle high boost over 1 bar. But then again why would you use a stock ecu running over 1 bar? Running over 1 bar I would use a standalone or a piggy back ecu with a 3 bar map sensor .
[Modified by ekb18c, 4:08 AM 1/23/2002]
[Modified by ekb18c, 4:09 AM 1/23/2002]
Old Jan 22, 2002 | 07:11 PM
97integraLST's Avatar
Default Re: (Ken) I'll take them! (ekb18c)
Check Valve, Fish Store, 2.50$
Old Jan 23, 2002 | 09:00 AM
turbopanda's Avatar
Check valves wont handle high boost over 1 bar. But then again why would you use a stock ecu running over 1 bar? Running over 1 bar I would use a standalone or a piggy back ecu with a 3 bar map sensor.
That's what I am running, a piggyback computer, the Link ECU, which controls my ignition timing, boost, VTEC (even though I don't need to adjust this, stock setting is best, especially on a SOHC VTEC engine) and additional fuel injectors. And I use it with the stock ECU. Its fast, and its reliable. It even improved my fuel consumption. Probably because the piggyback only works when it detects boost (there is a built-in 3bar map sensor inside the piggyback ECU, which I must connect a vacuum hose to). I don't use a regulator either. Stock main fuel injectors, with 4 additional B18C fuel injectors welded into my intake pipes. No worries.
Old Jan 23, 2002 | 09:13 AM
TurbodCX's Avatar
hey 4dgsr at work ,do you still have the missing link?? if so email me ,
@ brianarbogast@yahoo.com i want the check valve . im on the east coast (virginia)
Old Jan 23, 2002 | 10:46 AM
GSRwBOOST's Avatar
Default Re: need Missing Link valve (TurbodCX)
i hate fish tank valves... they worked sorta.. got the missing link installed and the car runs great.. the vacume line with the CV's came off once or twice... and it sucks...
fixing car on a date sucks period... missing link 65$... no worries, happy date.. jake gets laid.... all is good...
djnikko
Sep 16, 2003 07:36 AM
harryg
Sep 7, 2003 08:05 AM
DeL SLo
Jul 20, 2003 11:12 AM
RuthlessEF-9
Dec 8, 2002 01:36 AM
PROFILES2000
Jul 31, 2001 07:08 AM
