400+hp = what clutch?
I am trying to decide what clutch and/or flywheel to go with in my car this year. I used a Centerforce DF the last 2 years with no problems. I don't know why but it never slipped even on 20/8 slicks. But I think, with a little more power and the better chassis/tire setup for this year, it's not going to hold and is probly about to wear out anyways. So I'm looking for input on what is a good clutch for a possible 10sec street car. I don't plan on running bigs slicks so I don't need the strongest thing out there. Also my budget is getting kinda low so I gotta keep that in mind. Any input is appretiated.
Re: 400+hp = what clutch? (9psiHybrid)
either clutchmaster STAGE 4 or 5 or ACT EXtreme PP combo with 6puck or go with custom ClutchNet setup from Ben.
All of the above mentioned clutches should cost under 400 bucks with all bearings etc.
clutchmasters twin disc is the only way to go. pretty much drag only. or spend the 3 g's and go for the tilton.
and i'd plan on running 25" slicks atleast. you could have all the power in the world , but if you can't get it to the ground............
[Modified by jinxproof99, 11:34 AM 1/19/2002]
