Some probs, narrowed it down
Old Jan 20, 2002 | 03:56 PM
1.8EG-T's Avatar
Default Some probs, narrowed it down
I am getting closer to solving this headache.Really rough sporadic idle 500-1500 or so rpms, dies once heated up and gas is pressed. Vac is around 12 at idle. I have chagned every vac hose known to man, and stillno luck, disconnected the fmu and tried just the stock fpr, no luck.
I did a compression test, 190, 190, 190, 190 while heated
I have a big black stain on my wall and when I take the sprak plugs out, they are dripping with gas and have plenty on black carbon on them, even after changing them out, still get carbon after 10 minutes of idle.
Me and a few others thinkit is fuel pressure related, can the stock fpr just stick open, or the inline pump overwhelm the stock fpr.
If so what typ eof fuel pressure reg. do you suggest, b and m, sx, paxton?
Opps, 91 teg, lsvtec, drag gen 2 kit, pr3 ecu.
Old Jan 20, 2002 | 06:21 PM
1.8EG-T's Avatar
Default Re: Some probs, narrowed it down (hybridrex)
Old Jan 20, 2002 | 06:26 PM
LsTurbo91's Avatar
get a fuel pressure gauge and check your fuel pressures.
Old Jan 21, 2002 | 11:15 AM
1.8EG-T's Avatar
Default Re: Some probs, narrowed it down (LsTurbo91)
Thanks god...I found my problem. Missing link connectin was real loose, vacuum hose jsut slid right off. Got vac up to 18-19 range and the car purrs like a kitten.
afnan
Jan 12, 2014 05:16 AM
Ruben19
Oct 11, 2006 08:30 AM
civic_driver
16
Sep 15, 2005 12:49 PM
Tchleung
Oct 18, 2004 01:48 PM
3rdGteg
Oct 25, 2002 09:21 AM
