One last time.....
Old Jan 19, 2002 | 03:57 PM
Blown90hatcH's Avatar
Default One last time.....
Okay.....before this tranny goes back in....Lightened flywheel. I can get a clutchmaters 7.5 lb flywheel for a good price. Or should I get the ITR flywheel for a little less then the clutch masters. Price isnt too much of an issue as long as it is under around 250. I also have my stock gsr flywheel. I am just time pressed on time. If you have any other options that I might be interested in...Please post. Here is the setup:
60-1 turbo, Built B18C, SpeedPro engine management, Street boost around 15psi, track boost levels around 30psi.
Thanks for voting.
[Modified by Blown90hatcH, 7:43 PM 1/19/2002]
Old Jan 19, 2002 | 04:23 PM
FAST94GSR's Avatar
New User
Default Re: One last time..... (Blown90hatcH)
lighter flywheel=faster spool up and faster revs. go clutchmasters
Old Jan 19, 2002 | 04:45 PM
bigTom's Avatar
Default Re: One last time..... (FAST94GSR)
houw about a twin disc clutch for ur setup
Old Jan 19, 2002 | 06:43 PM
Default Re: One last time..... (Tom)
I have the clutch.....just debating on the flywheel. I have the Iron disk with dual diaphram clutch on there now.
Old Jan 19, 2002 | 07:47 PM
bigTom's Avatar
oh...ok... i would go with a one piece flywheel if i was u... something like a jun or whatnot
Old Jan 20, 2002 | 07:47 AM
Hmmmm....
Old Jan 20, 2002 | 01:55 PM
JDM_DOHC_SiR's Avatar
New User
Yes Get the CrapMasters
Old Jan 20, 2002 | 02:13 PM
xxplosif1's Avatar
Default Re: One last time..... (JDM_DOHC_SiR)
question: why would you want to go with an ITR flywheel? Is it gonna be OK for your set up? Is it gonna hold fine?
Old Jan 20, 2002 | 02:45 PM
Default Re: One last time..... (xxplosif1)
Yes, it would hold fine. I can get one for cheap....but I want the best one. I only want to put it on once.
Old Jan 20, 2002 | 04:39 PM
xxplosif1's Avatar
Cool
I have a ITR PP and clutch disc on my 92 Integra RS. What should i do to make it hold even more? I didn't know that the ITR PP would work fine with lots of boost like you'll be running.
[Modified by xxplosif1, 1:41 AM 1/21/2002]
Old Jan 20, 2002 | 07:17 PM
Etylorcen's Avatar
You go too light on your flywheel you're going to lose all that mass for your launch on the strip.
Old Jan 20, 2002 | 07:37 PM
Adi Radoncic's Avatar
On Fire!
I would just say that if you don't have the full throttle shift option in your standalone system that i would go with the ITR fly wheel because that clutchmasters flywheel will get the rpms up there quick but they are also gona come down quick so your gona loose some boost while shifting unless your one of those guys that doesn't take their foot of the gas while shifting
Adi
Old Jan 20, 2002 | 08:07 PM
Default Re: One last time..... (newgsr)
Definately
xxplosif1's Avatar
doh!
Sorry, my bad, thought you were talkin about the ITR pressure plate...
drintegra
May 14, 2006 04:35 PM
Rocks
Aug 23, 2004 12:27 PM
Goldfingiz
Jul 16, 2003 09:47 PM
Big Teggie
Sep 9, 2001 02:51 PM
SPOON_BeIgHtEeNsEe
Aug 29, 2001 12:54 PM
