Strange EGT's
Old Jan 22, 2002 | 09:22 PM
Mase's Avatar
Default Strange EGT's
Old Jan 22, 2002 | 10:21 PM
sparkz's Avatar
Default Re: Strange EGT's (CDooMe2)
Sounds pretty normal for cruising. The ECU leans the mixture a bit when you're just cruising to save some gas
Old Jan 23, 2002 | 06:45 AM
VTC_CiViC's Avatar
but as soon as i hit the gas and start to boost it will go back down, ..
Because that's when you're engine is getting the extra fuel it wants dropping your EGT's..
Old Jan 23, 2002 | 06:56 AM
rtype11's Avatar
I dont know how long the drive is but prolonged heat in that range does embrittle the head and heat soaks the quench area which if hot enough could detonate, I like running my car real rich on the highway - its a trade off. I am pretty sure running full 3" exhaust would lower temps by 100C. also consider backing off timing a couple of degrees as you obviously have too high max cylinder pressure under zero load. this may cool things down a bit two. also setting cams to overlap more will also cool things, but not make more power.
Old Jan 23, 2002 | 08:03 AM
TurboTypeR98's Avatar
New User
I used to have the same problem except my egt's would be around 780 c while cruising on the freeway. I had a 12:1 fmu with 310 injectors. I recently swapped out the fmu disc to an 8:1 and adjusted the fuel on the v-afc and my egts dropped by 70-80 c while cruising. I was thinking that when I had the 12:1 fmu I had to pull more fuel(ex:-20%) then with the 8:1 fmu(ex:-15%). So while cruising and not boosting, it was pulling out fuel making the car run lean and have higher egts. What fuel controller do you have?
Old Jan 23, 2002 | 11:34 AM
Mase's Avatar
Default Re: Strange EGT's (TurboTypeR98)
I only have the inline pump and 12:1 fmu, everything else is stock, i kinda ran out of money for the car, my dad decided i had to pay my fraternity dues this semester, so im SOL, and I also started to put aside some money for a new clutch.
Old Sep 29, 2004 | 08:38 AM
Finest's Avatar
Default Re: Strange EGT's (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">I only have the inline pump and 12:1 fmu, everything else is stock, i kinda ran out of money for the car, my dad decided i had to pay my fraternity dues this semester, so im SOL, and I also started to put aside some money for a new clutch. </TD></TR></TABLE>
The EGT's are fine. But here's a solution to your money problems. I have a few friends that need to get tuned, you can try that and I'm sure they'll give you a few bucks in return.
Old Sep 29, 2004 | 09:04 AM
Blackack26's Avatar
Default Re: Strange EGT's (Finest)
grave digga
crxhybrid85
Oct 14, 2006 07:13 PM
vtec-adykt
Mar 22, 2005 02:23 PM
slowpokesi
Nov 6, 2004 04:14 PM
HybridKOOP
Oct 15, 2002 01:41 PM
turbotec
Mar 1, 2002 04:27 AM
