Can someone please help me pic a hondata system for my setup.
Ok heres my setup
2000 civic si
7.5to1 compression
eagle rods
drag3 turbo setup with vortec bdfpr
and a bbk 255lph fuel pump
I want to run high boost ( reason for such low compression) and i want to play it safe. The rebuild was not free so i dont wann do it again. I run at the track alot so the drag launch option is nice however the vtec contorlling part is no big deal. I also like the rev limiter, but does it do it via spark of fuel(like stock)?
Any help would be apriciated. I dont really have a good laptop but my home pc is great. i dunno if it can be used any way. thanks for the help
2000 civic si
7.5to1 compression
eagle rods
Re: Can someone please help me pic a hondata system for my setup. (turboex)
Ahh that compression is so low. Should have sleeved the block, or gone with something like 9.0:1.
Dustin
Dustin
Re: Can someone please help me pic a hondata system for my setup. (philo)
AFAIK the rev limiters are all fuel-cut type. I'm running stage 3B and its great for the track with full throttle shift and launch limiter. I vote for 3B, no reason to go higher unless you want the ability to make your own programs. At that rate, I dont know that stage 4B is very cost-effective compared to speedpro, etc... Just my $.02, EV.
Re: Can someone please help me pic a hondata system for my setup. (turbo01gsr)
oh thats for the help. as for the compression being low i just wanted to play it safe. and as of now im driving the car without the turbo and it drives fine. not much diffrent from stock. so ill get by. thanks for the help
why sould you launch or shift at full throttle with a fuel cut rev limiter??????? no fuel+lean condition=detonation am i not right????? dont have a hondata but will and will run a digital 6 with launch limiter ( they use spark cut). just my opinion. do what you want.
Re: Can someone please help me pic a hondata system for my setup. (lbz34)
yeah thats why i was asking. i always though it was bad too. anyone got any info on this? thanks
