tial wastegate only boostin 3-4 lbs
New User
i just got my car up and running again problem is boost gauge is only reading 3 to 4 lbs, hondata logger reads as low as 2 sometimes. someone i talked to said that they got low boost with the tial, we put in the valve seats no leaks whats up? will a boost controller be efficient when used w/ my wastegate? the spring is for 7 lbs i believe.. got it from importparts.com.
Re: tial wastegate only boostin 3-4 lbs (turbo01gsr)
My TIAL did the same thing, turned out the bolts weren't down all the way. Since TIAL's use the Hex bolts, it was harder to tighten them enough. I used regular bolts and was able to get sufficient torque on them, boost is good now.
Re: tial wastegate only boostin 3-4 lbs (dustin)
What pressure source do you have the side port connected to?
It's the .5 bar tial?
BTW, so far I have my BOV, FMU, and boost guage tapped into the same source(my FPR line). Will that effect this assumption?
[Modified by maxim, 1:14 PM 1/24/2002]
Re: tial wastegate only boostin 3-4 lbs (maxim)
movethe BOV to a larger vacume line, like off the intake manifold... i had to do that for a couple problems when i first installed mine..
Smarter than you
I have a .3bar spring and i usually only see .2, .25bar, until 4th gear it will reach .3.. possibly u have a .3bar spring
New User
Re: tial wastegate only boostin 3-4 lbs (DIRep972)
if i get a boost controller will it solve this nonsense? lookin at greddy profec B...also cuz i plan on boostin around 9 lbs.
Smarter than you
Re: tial wastegate only boostin 3-4 lbs (Phoenix-R)
that happened to me also, u just have to play with ur fpr
You could have a defective boost gauge. I did, my gauge would read in vacuum with the car off, I adjusted my boost controller so that the gauge would read just above 5psi when I was at full boost. The car was really fast, but the vacuum reading always bothered me so I bought another gauge that read 0 with the car off, the first pull I did boost read 8 psi. So my first gauge was off by about 2 1/2 -2 3/4 psi. Luckily I didn't tyr to boost any higher with the original gauge.
Damian
Damian
moesrex
05-15-2006 08:34 AM
