HELP: DragIII oil feed line & Autometer oil pressure sensor.
I need a brass T to install an Autometer Oil pressure sensor.
My car currenly has just a straight brass fitting which connected to the oil feed line. Anyone knows the part number for it and where to buy one?
TIA.
TIA.
Re: HELP: DragIII oil feed line & Autometer oil pressure sensor. (CivicNewbie)
Go to ACE Hardware or any hardware store that sells compression or gas fittings. When I stripped the threads on the T for the oil feed line I went to ACE Hardware and found and identical T. You can probably find a T with two outlets also.
[Modified by maxim, 11:15 AM 1/23/2002]
