Integra Track Weight
Old Jan 23, 2002 | 09:12 PM
LsTurbo91's Avatar
Default Integra Track Weight
Has anybody weighed there integra with everything removed like spare, jack, maybe 2 gallons of gas left? If so how much did it come out to be? including driver?
Old Jan 23, 2002 | 10:59 PM
BoM's Avatar
BoM
Default Re: Integra Track Weight (LsTurbo91)
around 2400lbs
1/4 tank of gas, NO air bags, sunroof, 1seat, sound deadening, air conditioning, radio, carbon fiber hood...take off the bumper supports for about 40 more lbs
then add the driver....
integras heavy.
i believe it can get to 2300lbs easy, but 2200 is hard!
[Modified by BoM, 3:00 AM 1/24/2002]
Old Jan 24, 2002 | 05:57 AM
PROFILES2000's Avatar
Default Re: Integra Track Weight (BoM)
mine weighs 2450 with out me in it all i did was remove both front and back seats and put 2 sparco torinos in there (which are heavyer than you would imagine how about just under 40 lbs per seat with out brackets)
Old Jan 24, 2002 | 06:30 AM
rtype11's Avatar
I have the following removed from my LS:
mud flaps, cruise control including pedal linkage, all AC under dash too, back half complete interior incl. moldings, PS, brake heat shields up front, distibutor internal coil, metal plate from glove box, air bags including support and ECU, evap can, spare & jack. ac bracket replaced with Aluminum bracket. the stuff i have added basically brings a lot of the wieght back I am at 2350.
Old Jan 24, 2002 | 06:50 AM
b18b98's Avatar
Default Re: Integra Track Weight (rtype11)
i got mine to weigh 2512 with the passenger seat, back seats, rear carpet, jack, spare and moldings removed.
Old Jan 24, 2002 | 07:19 AM
LsTurbo91's Avatar
Default Re: Integra Track Weight (b18b98)
I thought a LS weighed around 2800lbs with driver and spare removed?
Old Jan 24, 2002 | 07:31 AM
b18b98's Avatar
Well mine was 2512 with me in it. I weigh around 170lbs. I also had about 1/2 a tank of gas. I have a 98 RS and my integra doesn't come with a sunroof. I remember reading in the brochures that the LS is about 2650 with out driver.
Old Jan 24, 2002 | 07:35 AM
rtype11's Avatar
Probably read the door panel - that is fully loaded all fluids, think 2 200lbs passengers.
Old Jan 24, 2002 | 10:12 AM
dustin's Avatar
GVWR counts the seats full of 180lb passengers and a full tank of gas.
Old Jan 24, 2002 | 10:24 AM
97integraLST's Avatar
Default Re: Integra Track Weight (dustin)
mines 2800+ with me included
Old Jan 24, 2002 | 11:30 AM
cyan1de's Avatar
Default Re: Integra Track Weight (97integraLST)
FYI the RS is lighter than the Type R. but anyway, i'm not sure how much mine weighs--- removed rear seat, jack + full size spare + rear carpet + toolbox + emergency kit thingy and that's all i have, rest stock interior
Old Jan 24, 2002 | 12:10 PM
Rah Rah's Avatar
Default Re: Integra Track Weight (cyan1de)
At the track my LS with me included (175 lbs.) the spare removed, front passenger seat removed, and a 1/4-1/8 tank of gas was 2,684 lbs--so 2,509 lbs without driver.
[Modified by sando112, 4:12 PM 1/24/2002]
[Modified by sando112, 4:33 PM 1/25/2002]
Old Jan 24, 2002 | 09:08 PM
Incognito's Avatar
Default Re: Integra Track Weight (sando112)
Integra Type R
All seats removed except driver's.
Cat back exhaust removed.
Spare tire/jack/tools/tire cover board thing removed
Rear bumper cover removed.
Rear bumper reinforcement removed
1/8th tank of gas.
150lb driver (me)
15" Spoon wheels in the back.
13" Lenso wheels w/slicks in front.
2450lbs exactly, so 2300lbs without driver.
slimsdizz
Jul 13, 2011 05:55 AM
shiftat9kay
Oct 26, 2008 05:29 AM
Clutch502
Dec 14, 2005 07:29 PM
Catch 22
28
Jan 23, 2002 08:17 PM
