Pump it (oil system topic)
Old Jan 23, 2002 | 07:48 PM
rondigs's Avatar
Default Pump it (oil system topic)
Has anyone had any experience modifying oil pumps. I've heard that the oil pumps presure releif spring can be shimmed for like 10 to 15 psi worth of oil pressure. Any insight??
Im building an LS/VTEC: sleeved, forged, polished. blueprinted, and boosted. Would the extra oil pressure help out??? Thanks.
Old Jan 23, 2002 | 08:26 PM
ekb18c's Avatar
Default Re: Pump it (rondigs)
shimming the oil pump is a common thing. And yes the extra psi of oil will help, just think of how many componets are using oil. A oil cooler is also another good idea you might want to invest in, as well as a moroso oil pan(which holds more oil). Turbo motors tend to eat oil like nothing.
Old Jan 23, 2002 | 10:40 PM
Xerxes's Avatar
New User
Default Re: Pump it (ekb18c)
higher oil pressure may be good for your engine, but it's bad for your turbo. Make sure you have some sort of a restrictor to reduce the pressure that your turbo seals have to experience.
-Xerxes
Old Jan 23, 2002 | 11:12 PM
threatcon13's Avatar
New User
Default Re: Pump it (Xerxes)
-Xerxes
what could be used as a restrictor?
Old Jan 24, 2002 | 05:24 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Pump it (turbo01gsr)
I discourage any modifing of the stock pump. Ive seen two built motors spin rod bearings because they did the same thing.
art
Old Jan 24, 2002 | 05:52 AM
RGAZ's Avatar
New User
Its called an orifice and basically it is a metal disc with a hole in it.
Figuring out the hole diameter is hard part.
Randy
Old Jan 24, 2002 | 06:35 AM
Sleeper's Avatar
Porting the inlet and exit inside the pump and filling in the end of the pump (right at the exit) with liquid aluminum, like Devcon, will work wonders. No shims. My oil pressure is 25-85 psi with the modded B20BorZ/B18C/B18C5pump on a B20.
Old Jan 24, 2002 | 06:36 AM
rtype11's Avatar
Default Re: Pump it (RGAZ)
Randy
I call it a washer. you can maintain the desired oil flow pretty well just by choosing your line size properly, I only use a -3 line on my T60
Old Jan 24, 2002 | 07:17 AM
rondigs's Avatar
Default Re: Pump it (rtype11)
Thanks for the replys. Seems we have mixed opinions. I've heard of porting and filling to get more pressure as well. Just wanted to hear other peoples experiences and opinions.
Old Jan 24, 2002 | 07:37 AM
rtype11's Avatar
with the gear pumping at the same rate pressure increases and volume decreases, think it s a basic principle - dont think it is different for oil pumps, pls correct me without flames if i am wrong
wezzel19
Oct 9, 2006 09:05 AM
tcontesh
Jun 29, 2006 01:46 PM
crxsiperf
Nov 23, 2005 04:36 PM
swlabhot
May 30, 2004 02:26 PM
jasonkits
Apr 9, 2003 01:19 PM
