few questions about turbo an safety
im in the process of getting a new car, i cant decide, i can either get a type r an it will be stock for a long time, or my friend is selling his 99 hatch, he just put a b16 in like 3 weeks ago , the first time he raced, he got caught , his parents took his car an there sellin it cheap, 6,000 grand cheap, anyway if i got it id go turbo, i wanna get like a rev hard or drag kit, what would you guys suggest a few little extra things i should get to mayeb help keep it safe an maybe some more boost, like a headgasket , or injectors, any help is greatly appreciated
thanks
eric
[Modified by vtecjunkie, 11:34 AM 1/22/2002]
thanks
eric
Re: few questions about turbo an safety (vtecjunkie)
#1- I'd get the hatch
#2- Get a good kit (DRAG etc..)
#3- take care of the finer points like injectors, standalone's etc..
#4- NOW you can safley boost higher numbers
and another thing , hondata, i want it , but i see soem many diffrent levels , or wahtever you call um , which one whould you suggest , i have plans on building the engine to make it safer, an faster, just not for like a couple months, id be cool for that long right,
thanks
eric
thanks
eric
With all that money you save over an itr you could do a lot to that hatch. Get a turbo kit, injectors, rods, valves, along w/ some turbo headwork, hondata stage 3b + dyno time.
Re: few questions about turbo an safety (01geeser)
what injestors would you recomend, an what are some other little things that can help out , i cant get rods etc right away, like i was thinking like a headgasket, i hear good stuff about inlinepro, are there diffrent kinds, , an how much boost can i push , with the kit,injectors, a vafc,avcr, an whatever other things you guys suggest, only reason i want the vafc , an avcr, is my boy has vafc for cheap, an i get hooked up a avcr,
thanks
eric
[Modified by vtecjunkie, 6:04 PM 1/22/2002]
thanks
eric
If you get a Hondata 2b+, don't worry about getting larger injectors or a VAFC. The Hondata will take care of all that for you. If you go with the Drag kit T04e for your engine, get a stronger/lighter clutch/flywheel combo along with the Hondata 3b along with some rods, retainers, a block guard, reinforced sleeves and you should be set.
New User
When I saw the title "turbo and safety", the first thing I thought of was upgrading brakes, stickier tires and tuned suspension.... damn I must be getting old.
Re: few questions about turbo an safety (mercury)
i have both taken care of im gettin a full type r 5 lug conversion, it has new brakes an no tires, what are some good tires to put on , id like to get 205-50 they seem like pretty good size
New User
not great in the rain supposedly (haven't tested them myself) but great in the dry!
-Xerxes
Smarter than you
get the hatch, if u do pistons/rods u wont need the headgasket.. basically if u get the hatch, build the bottem end, turbo it w/ good fuel management, you will be close to unstoppable..
CiViC SiR
19
03-18-2002 06:13 PM
