Detonation...sad nite
Old Jan 24, 2002 | 09:09 AM
98Psi ITR's Avatar
Default Detonation...sad nite
Took of the head last nite and found 3 damaged pistons. On the intake side looks like some small chunks have disappeared from 1,2, and 3. Still have to drop the pan and take them out, but this is the general prognosis. Luckily I have developed a "broken motor fund" over the last year and can make the repairs without too bad a hit.
Old Jan 24, 2002 | 09:11 AM
Rob03Pro5's Avatar
Default Re: Detonation...sad nite (98Psi ITR)
That sucks man. What is your setup like? How do you think you blew it?
Old Jan 24, 2002 | 09:13 AM
VaporTrail's Avatar
New User
that sucks, but props for planning ahead! I was in the midst of building my second block when my current let go.
Old Jan 24, 2002 | 09:14 AM
TurboTypeR98's Avatar
New User
what kind of pistons do you have? What are your plans now?
Old Jan 25, 2002 | 07:39 AM
98Psi ITR's Avatar
Default Re: Detonation...sad nite (TurboTypeR98)
those were JE and I'm looking for one now that is taller. If not then I'll stick these back in.
15psi...I was told that at this boost level or higher, total timing should only be around 20 degrees (full boost).
I thought I was pretty safe. VP 103 gas, took it to the dyno for tuning. I'm gonna try and the head to the shop and pull a piston (too busy) today.
Old Jan 25, 2002 | 07:41 AM
VTC_CiViC's Avatar
Any idea how this happend?? Just "out of nowhere" detonation?
Old Jan 29, 2002 | 04:32 PM
98Psi ITR's Avatar
Default Re: Detonation...sad nite (VTC_CiViC)
bad gas.
Old Jan 29, 2002 | 04:51 PM
DLB1994's Avatar
didnt u hear it the popcorn poping in the engine and u could have just let out of it and go retard your timing some more
Old Jan 29, 2002 | 05:15 PM
Type-ARR's Avatar
Default Re: Detonation...sad nite (DLB1994)
Is it me or has a lot of FI R's been blowing up these past few weeks......
good luck with the rebuild
_kiid
Sep 7, 2009 07:28 PM
00-501itrspec
Mar 18, 2008 06:02 PM
Magik123
Jul 3, 2007 12:20 PM
hondahatch741
Jun 10, 2005 11:38 PM
15psi of fun
Nov 7, 2003 03:36 AM
