Need some advice on getting my head built.
Old Jan 22, 2002 | 07:16 PM
turbo hybrid hatch's Avatar
Default Need some advice on getting my head built.
I am fully building the bottom end of my b16a (golden eagle sleeves, je pistons, eagle rods, etc.) and I now I need to get my head rebuilt. The valve stem seals are bad, so I am just going to go all out and build the entire head. Couple of questions before I procede:
1. It is beneficial (adds horsepower) if I up my redline on my stock vtec cams to 8500?
2. What is the best spring/retainer combo for the money?
I was originally going to have a 9000 rpm redline with my turbo, but after my friend had alot of up keep on his bottom end (tearing his engine down and checking the bearings every couple of months) I think that I just want to keep the stock redline or move it up a little. Any thoughts/comments on having a higher redline with turbo?
Thanks, Jeff
Old Jan 22, 2002 | 07:35 PM
ekb18c's Avatar
Default Re: Need some advice on getting my head built. (turbo hybrid hatch)
You may not always gain HP by just upping the redline, you may acutally lose HP. If your going to get your head done, then might as well get it ported. Increasing the amt of air that flows through will gain HP given that you have enough spark and fuel to go with the extra air. Bang for the buck springs and retainers are Webcams.
ashb82
Aug 8, 2012 09:28 PM
b18a1da
Sep 23, 2009 01:13 AM
skn181
May 13, 2007 10:49 PM
Unsought Devil
Jul 31, 2006 05:21 AM
ilikehonda
Oct 9, 2005 10:06 PM
