Which aftermarket pistions are you running?
Re: Which aftermarket pistions are you running? (Markaccord95)
saw the list, just thought I would add acouple guys I know are also good - Wiseco and Ross, bith use same alloys and pretty sure ROss can make customs in a coulple of days
Re: Which aftermarket pistions are you running? (rtype11)
ross pistons are very nice, but i had problemd dyno tuning a motor with them in it. It was just flat compared to std je piston.
But the AEBS guys use the ross with mucho sucess. They run like 50pounds on them in the focus.
Re: Which aftermarket pistions are you running? (Slow_ass_4dr)
I'm using JE.. i dont have a Honda..but still, JE's are one of the best in my book.
Mine are 83mm (1mm over stock) w/ 8.5:1
Also added the accumulator grooves (some call it anti-detonation grooves)
My motor is currently being built by A.E.B.S.
They highly recommend Ross pistons. Here is what is going in my new motor::
Those are Crower rods and Ross pistons vs Stock
Re: Which aftermarket pistions are you running? (TurboIntegra)
hey turbointegra, is your car the black type r with the red sparcos at AEBS?
Re: Which aftermarket pistions are you running? (boostedeg6)
boostedeg6-- Yeah that is mine. It has been there forever! They are lagging big time.
Why I assume you saw it there?
You should change it to Wiesco instead of Endyn and J.E/SRP both made by the same people just differnt design..
Endyn Roller Wave's 9.5c/r ZC
Jeff Frank
Jeff Frank
Re: Which aftermarket pistions are you running? (G_Man604)
I'm not a hater but F*CK ARIAS! I order custom pistons from arias almost 4 months ago. Said they were backed up the *** in orders. They finally send me pistons, but they're just plain off the shelf pistons. Called them up, told them the situation and they said told me to just order from someone else. WTF is that?!?
I was going to get wisco(rw) but they seem to lag on custom pistons. So I ordered my pistons from Ross because they are known for making custom pistons fast and on time(fingers crossed*).
turbo Si
06-28-2002 12:00 PM
