Turbo on a high milage car
New User
Re: Turbo on a high milage car (97CivicFerio)
Yeah, my motor is in A+ condition. It is also a matter of putting the right components on the car to go with the turbo. The quality parts always last longer than the money you saved on crap.
Re: Turbo on a high milage car (99 HXagon)
I so believe that. I would rather spend more money now and have a long lasting item than spend more to replace a crappy item.
Banned
have talked to a guy o this boar (jinx) who has over 140,xxx with stock internals and a inline pro headgasket and a custom turbo kit runnin 11.30's ...its never to many miles till its to late
Will you make something up for me please?
Re: Turbo on a high milage car (On Point EK)
I put my turbo in at 115K miles. Too bad right now at 118K miles I had to take it apart cuz I spun a rod bearing.
Re: Turbo on a high milage car (shamoo)
I have 87,xxx miles on my car right now. I would like to have a turbo on it by 90,000. What are some parts that should be replaced before the turbo?
Head Gasket?
Timing belt?
water pump?
Anything else?
Head Gasket?
Timing belt?
water pump?
Anything else?
Re: Turbo on a high milage car (BLK94RS)
I had my timing belt and water pump done at 101K miles. Now I sit near 105K, and the turbo will be going on here in a couple months. For your mileage I think just have it checked over and replace things if they need it, otherwise GTG.
New User
Listen for any unusual noises. Do a valve clearance adjustment. Compression check or better yet, leak-down test. If anything is even remotely fishy, the turbo will just accelerate the death of the engine.
