Just purchased Moroso Oil catch can. Need help hooking up!
I have an ls motor with a turbo on it. Just curious on how othre people have hooked theirs up. An info will be great and pics would be even better!Thanks.
New User
Re: Just purchased Moroso Oil catch can. Need help hooking up! (Turbocivic98)
cspeedracing.com not sure if that's the correct spelling there might be a hyphen between c and speed.
since on the LS block theres no oil seperater box already, you run one line off of the valve cover and the other end goes to the vacuum source on the manifold. i have a skunk2 manifold and i wll be using the bigger plug thats right in the middle.
Re: Just purchased Moroso Oil catch can. Need help hooking up! (sparkz)
My B18B does have an oil seperator on the back of the block- how does this change the catch can setup?
Thanks
Ben
Thanks
Ben
oops i stand corrected. the catch can will go inline between the oil seperator and the manifold
New User
sparkz is correct. The catch can will go between the accumulator/seperator and the pcv valve on the manifold.
Randy
Randy
Maple50175
Honda Civic (2001 - 2005)
04-30-2010 03:43 PM
